Date/Time: Sat, 04 May 2024 05:20:47 +0000
Can't obtain symbol Russell 2000 daily
View Count: 1327
[2014-07-30 03:56:34] |
Willson - Posts: 176 |
I am using OEC data. I have no problem getting daily bars for ESU4.DLY or NQU4 daily. I cannot obtain and download daily bars for Russell 2000 futures. I want RLM-MU4 daily bars. I have no problem with intraday bars. Any suggestions Pls Regards |
[2014-07-30 04:07:04] |
Update the symbol settings as explained here: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings After that open a new Historical chart for the Russell 2000. If there still is no data, re-download the data by selecting Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-30 04:50:26] |
Thanks, but still no success. When I click to download new Historical chart, it says I need to rollover the symbol, I click to perform rollover and it suggests a symbol that makes no sense and will not download new data. I cannot delete any data since there is none. I have deleted all data files having ".dly" as type. What is correct symbol for Russell daily for RLM-MU4 (symbol for intraday)? Regards |
[2014-07-30 06:22:50] |
Have a look at this chart: http://www.sierrachart.com/image.php?l=1406701308794.png The historical chart symbol is shown at the top left. The symbol is RJU14 We see no reason why you would get a rollover message. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
