Date/Time: Wed, 01 May 2024 22:53:58 +0000
Market Stats and Volume Charts
View Count: 1117
[2014-07-29 16:23:06] |
User16114 - Posts: 153 |
Hi, I am a very happy SC and SC data user but do miss a feature available with other platforms. Could you add the ability to have a Market Statistic (ie: NISS or TICK etc.) start and finish at the same time a "Volume Per Bar" primary symbol starts and finishes? ie: an ES "Volume Per Bar" primary symbol with a Market Stat as a secondary symbol in the same chart, starting and finishing when the ES primary symbol "Volume Per Bar" starts and finishes. Thanks! |
[2014-07-29 16:45:25] |
With how the charts are designed in Sierra Chart, this is not technically possible to support. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
