Date/Time: Thu, 02 May 2024 02:09:54 +0000
How to upload custom data?
View Count: 982
[2014-07-29 00:09:25] |
User63160 - Posts: 9 |
I would like to set up a custom chart - very simple chart with a moving average below the chart, but I would like to run the MAs on custom data that I could upload or somehow enter daily. Can I link to an existing Excel spreadsheet that holds the data, or is there a way that I can upload it daily? Thanks. |
[2014-07-29 02:37:08] |
We recommend using ACSIL for this: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html You will want to use the Custom Chart variable: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scIsCustomChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
