Date/Time: Tue, 07 May 2024 19:03:06 +0000
Bulk import of Symbol and Trade and Current Quote Symbol
View Count: 1106
[2014-07-28 21:11:41] |
User89270 - Posts: 1 |
Hi, Is there a way to bulk import symbol to Trade and Current Quite Symbol mappings? E.g. I want to retrieve data for 100 symbols from IQN but map these the other symbols (the cfd variants) of Interactive Brokers so when the trade is placed on the chart (which sourced it's data from IQN) the trade is placed for the Interactive Brokers CFD. It's possible to do one by one through the chart settings screen but I was hoping there would be a quicker method. Thanks |
[2014-07-30 08:23:14] |
We apologize for the delay. We needed some time to consider this. Also, thank you for posting on the support board. When you say "IQN" what do you mean? ACSIL allows you to set the Trade and Current Quote Symbol: sc.TradeAndCurrentQuoteSymbol Here is information about ACSIL: https://www.sierrachart.com/index.php?page=doc/doc_CreatingDLLs.html So you can create a custom study to set that based upon the sc.Symbol of the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
