Date/Time: Mon, 29 Apr 2024 05:47:19 +0000
error studies TimeAndSalesBidSize
View Count: 1050
[2014-07-28 18:58:24] |
User21223 - Posts: 90 |
Hi I am using the data AMP TTNet. He wants to use indicator TimeAndSalesBidSize and TimeAndSalesAskSize. But the data provided by the indicator are wrong. Can I ask for a correct indicator. This is a very important studies. |
[2014-07-29 06:45:54] |
The data provided by the TimeAndSalesBidSize and TimeAndSalesAskSize could not be wrong but maybe there is a problem with the data received the TT FIX adapter which the studies are using. We would not expect any significant problem though.
