Date/Time: Sun, 28 Apr 2024 13:38:10 +0000
EMA values in Chart Values Window
View Count: 996
[2014-07-28 02:06:32] |
User68474 - Posts: 195 |
My Main Chart is a 15 second Standard Range Bar Chart in Region 1. In Region 2 I have added Ask/Bid Difference Bars Study based on the Main Price Graph from Region 1. I have added the EMA study to the Ask/Bid difference Bar Study with input "Close" and Length=10 (being careful to Base on: Ask/Bid Volume Difference Bar and "Chart Region 2"). I was assuming and hoping that the EMA value for any given bar would populate the Chart Values window upon scrolling Region 2 with the "Chart Values/Crosshairs". Of course, the "Y" value does show on the top line of the window, but I can only approximate the actual value of the point of intersection of the EMA with any given bar by eyeballing it while scrolling vertically on the bar and using that "Y" approximate value. I notice an exact (to two dec. places) value of the EMA in the Region Value Bar only for the calculation of the last(i.e. most recent) bar. I would think there would be the capability to scroll back to any given bar and get the exact value of the EMA at that moment. Thank you.
[2014-07-29 03:24:00] |
You should definitely see this in the Tool Values Window. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
