Date/Time: Thu, 09 May 2024 23:02:46 +0000
how to view chart order fills for past accounts on same data/trade service login
View Count: 322
[2023-12-08 16:00:30] |
User753428 - Posts: 158 |
when trading with prop evaluation companies, the way it works is you're given one Rithmic Paper Trading server login credential and everytime you buy a new evaluation, you receive a new TradeAccount id for that specific Rithmic Paper Trading server login credential. i would like to be able to analyze my trades i made in all of these past accounts and since Sierrachart saves all order fills locally in my computer, i am able to view the trading data for all past trading accounts via the Trading Activity Log by selecting the specific Trade account I had in the past on the dropdown menu inside the Trading Activity Log window. but there is no way to view the chart order fills for past Trading accounts unless it is an active account when logging into Rithmic. do you plan to allow functionality so that users can view these order fills from past trading accounts on the chart? i mean, since the order fill data already exists and we can already see all of the order fill data in numerical format through the Trading Activity Log, it should simply be a matter of allowing these fills to show on the chart right? |
[2023-12-08 18:57:06] |
John - SC Support - Posts: 31509 |
You can view the order fills on the chart you just have to select the specific trading account on the Trade Window for the chart (along with having the Order Fills set to show, of course). Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-08 19:05:09] |
i cannot select past trading accounts on the Trade Window for the chart because those trading accounts are no longer active for my Rithmic login. they no longer "exist" in Rithmic's system because when you purchase and attempt a new evaluation, you receive a new TradeAccount id and the previous one is deleted. all of the order fill data for these past trading accounts exist as a file locally in the Sierrachart folder and can be viewed inside the Trade Activity Log by selecting the trading account on the dropdown menu. i just want a way to be able to view them on the chart. |
[2023-12-18 14:55:40] |
Sierra_Chart Engineering - Posts: 14296 |
We will have to add a custom setting for this.
[2023-12-26 21:24:21] |
In the next release there is going to be a new Chart Setting for this under Trading: AdditionalManuallySetTradeAccount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-12-28 19:08:56] |
AdditionalManuallySetTradeAccount i just updated to the most recent release and attempted this but after inputting the account id under Trading: AdditionalManuallySetTradeAccount, whenever i try to select this manually set account through the trade account dropdown menu in the Trade Window, it just reverts back to the default account that's currently active on my Rithmic login. this also happens with CQG too. |
[2023-12-29 22:13:29] |
Ok we cannot spend further time on this now. It will have to be looked at later.
