Date/Time: Fri, 03 May 2024 18:06:57 +0000
Question: How to "permanently" set Candle Bar as the default price view.
View Count: 1603
[2014-07-27 21:36:30] |
knowle - Posts: 25 |
When a new symbol is downloaded price view is OHLC Bars. When an Analysis Study Template is applied to the chart price remains as OHLC bars. To view as Candle Bars this has to be changed via Chart → Chart Settings from OHLC Bars to Candle Bars. Question: How to "permanently" set Candle Bar as the default price view when applying a study template to a downloaded chart ? In other words without having constantly change OHLC Bars to Candle Bars when applying a Study Template to a fresh chart. Thanks. Date Time Of Last Edit: 2014-07-27 21:38:29
[2014-07-27 22:02:32] |
This is explained here: https://www.sierrachart.com/index.php?page=doc/helpdetails20.html The Graph Draw Type can also be changed through Chart >> Graph Draw Types. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
