Date/Time: Thu, 02 May 2024 15:23:23 +0000
How to change spread in Sim mode replay
View Count: 1193
[2014-07-27 15:25:48] |
User25311 - Posts: 30 |
Hello How can I set the bid-ask spread in simulated trading replay? For example, in FXCM broker we have +-0.40 of spread in XAUUSD, but when I'm replaying a chart in Sierra Chart Simulation mode it shows a 0.05 spread. This difference is very relevant for statistics, and I want to change it to a 0.40. Thanks |
[2014-07-27 22:05:31] |
What is the Global Settings >> Data/Trade Service Settings >> Intraday Data Storage Time Unit set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-27 22:11:54] |
1 tick
[2014-07-29 07:07:05] |
To reliably increase the spread you need to set Global Settings >> Data/Trade Service Settings >> Intraday Data Storage Time Unit to 1 Second and re-download the Intraday data in the chart. After you do this, you can increase the Tick Size in Chart >> Chart Settings to the spread that you want. Complete information about this is documented here: https://www.sierrachart.com/index.php?page=doc/doc_TradeSimulation.php#TradeSimulationBidAskPrices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-29 07:08:37
