Date/Time: Sun, 28 Apr 2024 13:51:42 +0000
Chart DOM DailyPL
View Count: 1048
[2014-07-27 03:53:57] |
ertrader - Posts: 645 |
Hi support, I must be doing something wrong for the trade DOM setup: Before orders closed: http://www.sierrachart.com/image.php?l=14064332945.png After orders close: http://www.sierrachart.com/image.php?l=1406433317992.png In the P/L after the orders are filled and closed, the DailyPL resets to 0P. Shouldn't it show the daily P/L? In this case 36 if all orders were closed right then? Thank you! Date Time Of Last Edit: 2014-07-27 04:01:09
[2014-07-27 04:25:38] |
It should. Refer to this page: https://www.sierrachart.com/index.php?page=doc/helpdetails81.html That page is for non-simulated trading but it generally applies to simulated trading as well. Was the position entered during a replay and then was the position flattened when you were not running a replay? If so, this is the problem. What is the Global Settings >> General Trade Settings >>Daily Stats Reset Time set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-27 04:44:58] |
Thank you... yes that was the issue. I exited after the replay. Exiting during the replay is accurate.
