Date/Time: Sat, 04 May 2024 20:06:12 +0000
trying to use IQfeed and IB to trade
View Count: 4316
[2013-05-06 01:52:40] |
What version of Sierra Chart are you running? Also, could you please login to this Support Board using the very same account that you log into Sierra Chart with. You can log out and log in at the top left of this page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-06 18:58:09] |
Update the version 970 to 971. It is possible the problem relates to Administrator level access. Please run all copies of Sierra Chart with Administrator access: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html#SharingWithAdminAccess Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-07 15:26:33] |
User32496 - Posts: 26 |
i updated to 971 now i have 2 SC with both IQfeed and IB but: but one of the dll i downloaded isn't loading. when trying to recompile it i get an error: "Source file "DeltaDivergence.cpp" is missing the SCDLLName line. Refer to ACSIL documentation." can it be that i had the v5 (which i found on the support board) and sc added it to user contribution as v3? when finished that and tried to compile i got this: -- Starting build of Custom Studies Source File: DeltaDivergence_v5.cpp. -- 18:14:37 "C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\DeltaDivergence_v5.dll" In file included from c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/string:54:0, from C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp:8: c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.h: In member function 'int std::basic_string<_CharT, _Traits, _Alloc>::compare(const std::basic_string<_CharT, _Traits, _Alloc>&) const': c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.h:2226:31: error: expected unqualified-id before '(' token In file included from c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/string:55:0, from C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp:8: c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc: In member function 'std::basic_string<_CharT, _Traits, _Alloc>::size_type std::basic_string<_CharT, _Traits, _Alloc>::rfind(const _CharT*, std::basic_string<_CharT, _Traits, _Alloc>::size_type, std::basic_string<_CharT, _Traits, _Alloc>::size_type) const': c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc:786:17: error: expected unqualified-id before '(' token c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc: In member function 'int std::basic_string<_CharT, _Traits, _Alloc>::compare(std::basic_string<_CharT, _Traits, _Alloc>::size_type, std::basic_string<_CharT, _Traits, _Alloc>::size_type, const std::basic_string<_CharT, _Traits, _Alloc>&) const': c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc:923:36: error: expected unqualified-id before '(' token c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc: In member function 'int std::basic_string<_CharT, _Traits, _Alloc>::compare(std::basic_string<_CharT, _Traits, _Alloc>::size_type, std::basic_string<_CharT, _Traits, _Alloc>::size_type, const std::basic_string<_CharT, _Traits, _Alloc>&, std::basic_string<_CharT, _Traits, _Alloc>::size_type, std::basic_string<_CharT, _Traits, _Alloc>::size_type) const': c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc:940:36: error: expected unqualified-id before '(' token c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc: In member function 'int std::basic_string<_CharT, _Traits, _Alloc>::compare(const _CharT*) const': c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc:956:36: error: expected unqualified-id before '(' token c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc: In member function 'int std::basic_string<_CharT, _Traits, _Alloc>::compare(std::basic_string<_CharT, _Traits, _Alloc>::size_type, std::basic_string<_CharT, _Traits, _Alloc>::size_type, const _CharT*) const': c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc:972:36: error: expected unqualified-id before '(' token c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc: In member function 'int std::basic_string<_CharT, _Traits, _Alloc>::compare(std::basic_string<_CharT, _Traits, _Alloc>::size_type, std::basic_string<_CharT, _Traits, _Alloc>::size_type, const _CharT*, std::basic_string<_CharT, _Traits, _Alloc>::size_type) const': c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.7.2/include/c++/bits/basic_string.tcc:988:36: error: expected unqualified-id before '(' token C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp: In function 'int scdll_DLLVersion()': C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp:10:1: error: redefinition of 'int scdll_DLLVersion()' C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp:9:1: error: 'int scdll_DLLVersion()' previously defined here C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp: In function 'const char* scdll_DLLName()': C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp:10:1: error: redefinition of 'const char* scdll_DLLName()' C:\SierraChart\ACS_Source\DeltaDivergence_v5.cpp:9:1: error: 'const char* scdll_DLLName()' previously defined here -- End of Build -- 18:14:39 |
[2013-05-07 19:32:44] |
1 more q. pls after connecting ib as execution, when trying to send an order (not simulated) from the trade window - i get nothing. no rejection nor execution on my ib account. also when connecting to ib at the open there is no request on ib tws for api connection any idea? thanks |
[2013-05-07 20:43:15] |
Do you have Trade >> Trade Simulation Mode On disabled? Check the Trade >> Trade Service Log for any Error messages when you submit the order. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-07 20:45:47] |
We need to see the complete source code you are building a custom studies DLL for. Please post it here.
[2013-05-08 04:57:23] |
trade simulation mode on is disabled trade service log is empty orders and positions window: i do get the orders but non are sent to IB (although sc do get the correct positions from IB) the code i trying to compile is the delta divergence that was posted by one of the users |
DeltaDivergence_v5.cpp - Attached On 2013-05-08 04:55:43 UTC - Size: 12.31 KB - 654 views |
[2013-05-09 02:28:32] |
Use the attached file.
DeltaDivergence_v5.cpp - Attached On 2013-05-09 02:28:29 UTC - Size: 12.28 KB - 759 views |
[2013-05-09 02:30:05] |
Is the status of the orders you are sending stuck in the Order Sent state? If so, please contact Interactive Brokers about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-09 05:24:26] |
thanks for fixing the cpp regarding the orders execution: the status of the orders are pending open (and the child orders are pending as well due to the parent not filled) that's what you call "stuck"? i have no problem getting from IB the correct position for that account... |
[2013-05-09 05:54:52] |
i spoke with IB api support in london after several tests they are sure i don't have any issues sending manual orders. after trying more thing i found that the problem is because i get @ES# from another SC (with IQfeed) and trying to send orders with that symbol to IB. when sending orders for the IB contract name ES-201306-GLOBEX there is no problem sending. so. how do i tell SC that @ES# = ES-201306-GLOBEX when executing orders? |
[2013-05-09 21:00:24] |
You need to set the Alternate Real-time Update Symbol to ES-201306-GLOBEX . This is explained in step 9 here: http://www.sierrachart.com/index.php?l=doc/MultipleServices.html#Sharing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-12 11:03:56] |
thanks. finally it's working and sending orders to ib now i went to do some backtesting i followed here http://www.sierrachart.com/index.php?l=doc/doc_Backtesting.php#ReplayBackTestingAutomatic but when tried to look over the results as in here http://www.sierrachart.com/index.php?l=doc/doc_Backtesting.php#ViewingBackTestResults i couldn't find a single trade (though i can c them on the chart)... any idea what am i doing wrong? here is the cpp file used |
new_system_test.cpp - Attached On 2013-05-12 11:03:38 UTC - Size: 6.91 KB - 749 views |
[2013-05-13 14:02:52] |
bump
[2013-05-13 16:17:50] |
How do you have the controls at the top of the Trade >> Trade Activity Log set? Did you select Replay/Backtest? It could be the automated trading system did not generate any trades at all. We do not provide help with automated trade system debugging. So we did not look at your source code. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
