Date/Time: Sat, 04 May 2024 14:12:08 +0000
ACSIL - Input parameters - Drop down list
View Count: 1575
[2014-07-25 22:54:08] |
ejtrader - Posts: 688 |
SC Team - Is it possible to use enum list for an input parameter and let the user select it from drop down list for an input. For drop selectable dropdown input - you do this something similar for setChartnumber - but don't know if it is possible to do this in general. Any study that I can refer for this purpose. Thanks For example: enum ival = {option1,option2,option3};
would like to let the user pick one of the above options as an input rather than typing 0,1,2 |
[2014-07-26 01:20:07] |
This has been supported for years now. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_scInputs.html#scInputSetCustomInputStrings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
