Date/Time: Sun, 19 May 2024 02:02:34 +0000
DTC port for client connection
View Count: 939
[2014-07-25 19:13:35] |
onnb - Posts: 661 |
hi - if I want to connect a client to receive market data with DTC, how do I know the SC port to connect to? Is there a place I need to configure this? Onn |
[2014-07-25 19:54:21] |
onnb - Posts: 661 |
just saw this: http://www.sierrachart.com/index.php?page=doc/doc_DTCMessageDocumentation.php#ConnectionLogon so in this case, I need to start SC with /Port:12345 as command line? |
[2014-07-25 22:12:35] |
We assume you are referring to the relay server: https://www.sierrachart.com/index.php?page=doc/doc_RelayServer.php That page explains how to set the port. The other documentation you linked to, is not relevant to the relay server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
