Date/Time: Tue, 21 Apr 2026 22:29:52 +0000
[User Discussion] - Study/Price overlay on Trading DOM
View Count: 700
[2023-12-01 09:08:24]
User740709 - Posts: 156
I was wondering how to overlay a custom study with marked levels into the Trading DOM but I am unable to even though I follow the HELP instruction for overlaying study/price on the Trading DOM.
What kind of studies can be used in the Study/Price overlay in the Trading DOM? Are there any limitations?
My custom study contains just horizontal lines and horizontal rectangles.
Thank you.
H.
[2023-12-01 16:54:53]
John - SC Support - Posts: 45720
In general, you can overlay most studies to the Trading DOM, but the way the information maps may make some studies work better than others.
You state that you are using Lines and Rectangles, which are drawings, and not studies. You can not copy drawings to a Trading DOM.
[2023-12-01 20:14:05]
Thank you. I mean that the study is drawing lines and rectangles for levels. So if I understand correctly, you mean that it is not possible to overlay a study that draws lines, right?
Thank you.
H.
Date Time Of Last Edit: 2023-12-01 20:16:11
[2023-12-01 21:45:19]
If the study is creating drawings (line, rectangle, Chart Calculator, etc.), then this will not work as drawings can not be copied in this way, they can only be copied using the option in the Chart Settings, and even then, they can not be copied to a Trading DOM.
