Date/Time: Fri, 03 May 2024 11:48:05 +0000
Connect SC to 2nd PC
View Count: 1304
[2014-07-25 16:32:18] |
EthanC - Posts: 44 |
Hi, I have a direct account with SC but I could not connect SC to my 2nd PC. "This login has exceeded the number of allowed systems. If you have restarted Sierra Chart or have closed Sierra Chart on one system and using it on another, you may need to wait 3 minutes since closing Sierra Chart, before logging in again." Despite waiting for 3-minutes or more, I still receive this popup. Date Time Of Last Edit: 2014-07-25 16:33:06
[2014-07-25 17:19:46] |
Due to the fact that your account has a discount on it, you are limited to using Sierra Chart on one system at a time. This restriction can be removed, but you will pay a higher price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-25 17:28:08] |
May I know how much is it?
[2014-07-25 17:47:24] |
40 USD a month for package 5. You can then use 3 systems at a time.
