Date/Time: Sat, 12 Jul 2025 00:48:29 +0000
Try non CLR version ?
View Count: 1302
[2014-07-25 02:39:03] |
User021827 - Posts: 174 |
If I download the non clr version to try it, will my current spreadsheets be overwritten ? I dont want to lose my current spreadsheets , but would like to try out the non clr spreadsheet functions. And can you switch back to other version ? thanks shane |
[2014-07-25 03:07:39] |
If I am using the special edition of Sierra through TTnet and AMP, will that not allow me to use non clr version? shane |
[2014-07-25 03:27:51] |
You can use the non-CLR version. Update through Help >> Download Latest Non-CLR Version.
[2014-07-25 03:29:05] |
Your current spreadsheets will not be overwritten because the file extension is different for spreadsheets in the non-CLR version.You can go back to the CLR version any time just by selecting Help >> Download Prerelease. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-25 03:30:00] |
thank you shane |
[2014-07-25 04:22:32] |
Will I have to rewrite all of the spreadsheet studies and alerts that I made ? The charts that had spreadsheets attached for studies had nothing in the formula cells. Is there a way to convert the spreadsheet or will I have to do them manually ? thanks shane |
[2014-07-25 05:54:08] |
At the present time, the formulas are not copied from old spreadsheets to new spreadsheets. This will be developed soon. Probably not for at least a month.
[2014-07-25 09:07:09] |
ok thanks sounds great shane Date Time Of Last Edit: 2014-07-25 10:37:44
