Date/Time: Sun, 28 Apr 2024 15:43:12 +0000
Not able to access any Bar period less than 30 secs ?
View Count: 1117
[2014-07-24 20:35:29] |
User59863 - Posts: 36 |
In: Chart Settings > Bar Period box When I change value of "...Secs per bar" to anything less than 30 secs eg. 5 secs, it only ever shows a minimum period of 30 secs? I thought Interactivebrokers had data every 1 second or so (if not actual tick data) Why this inability to access any Bar period less than 30 secs ? |
[2014-07-25 08:46:26] |
The historical data will be 30 seconds time units when using Interactive Brokers.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-25 08:46:35
