Date/Time: Sun, 16 Nov 2025 06:24:48 +0000
Data window and link symbols of two windows
View Count: 1720
| [2014-07-24 19:33:58] |
| User78439 - Posts: 23 |
I tried to open a window which contains all data of a chart, such as High, low, ... and indicator value, but I failed. In addition, when opening 2-3 charts, for example one for daily, other for 1m and another for 5m, there is a way to link these charts together so that when I change the symbol in a chart all charts in all charts are the same ? |
| [2014-07-25 01:29:44] |
1. Select Window >> Reset Windows. 2. Refer to: Working With Charts: Chart Linking Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-07-25 18:07:05] |
I like to add a small window which contains only chart data and all indicator values. They are shown by default at top of a chart.
| [2014-07-26 00:01:52] |
Refer to this section for instructions on how to do this: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
