Date/Time: Fri, 04 Jul 2025 00:11:06 +0000
Problem with Sierra Chart DOM
View Count: 2088
[2014-07-24 16:40:15]
User14382 - Posts: 3
I have poblem with the Sierra Chart DOM, values are in late compared to the DOM of Infinity/Transact
Best regards
imageDOM2.jpg / V - Attached On 2014-07-24 16:38:27 UTC - Size: 509.24 KB - 2537 views
[2014-07-24 17:03:20]
Are you referring to the market depth data? This is because the TransAct Bridge program is not set to send continuous market depth updates.
[2014-07-24 17:38:43]
Yes it's the market deph data, how can i resolve this problem ?
[2014-07-24 17:41:11]
Right-click on the TransAct icon on the system tray portion of the Windows taskbar and select Maximize.
Uncheck the "Ticks Only" option and then in Sierra Chart select File >> Disconnect and File >> Connect to Data Feed.
[2014-07-24 17:50:23]
Thank you it works :D
