Date/Time: Sat, 04 May 2024 03:59:55 +0000
SOUND ALERT
View Count: 1163
[2014-07-24 15:42:08] |
User82486 - Posts: 43 |
I use a study on my charts "Countdown Timer" How cab U create a sound alert that will trigger at 30 seconds (or more or less) bewfore the current bar ends? Fred |
[2014-07-24 17:41:19] |
Sawtooth - Posts: 3993 |
This spreadsheet study will do it: http://www.sawtoothtrade.com/free-stuff-11.html Date Time Of Last Edit: 2015-08-14 02:07:47
[2014-07-24 18:00:27] |
The Countdown Timer study supports an alert when a new bar is added to the chart but not 30 seconds before. This would require custom programming.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-24 18:00:50
[2014-08-05 19:52:29] |
tHE A;ERT SOUND WORKS FINE WITH A NEW BAR, BU ALMOST 20 SECONDS AFTER THE BAR HAS ENDED, iS THERE A CONCDITION THAT I CAN INSERT THAT WILL TRIGGER THE ALERT SOUND TOP ACTIVATE 30 SECCONDS PRIOR TO THE BAR END?
