Date/Time: Tue, 16 Jun 2026 02:49:50 +0000
aspect ratio
View Count: 1338
| [2014-07-23 19:35:00] |
| User57072 - Posts: 49 |
Can the aspect ratio in the x-y axis be kept constant. It changes when attempting to print.
| [2014-07-23 20:15:59] |
It may change some when printed. It is hard to make it exactly the same when printing. One thing you can do is select Chart >>Copy to Chart.bmp and then print out the chart from the graphics editor. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
