Date/Time: Mon, 14 Jul 2025 21:11:05 +0000
i want more time frame
View Count: 1176
[2014-07-23 17:35:13]
User29458 - Posts: 44
ok thanks for replay,
your last mail for time frame add
You can add custom ToolBar buttons for all of these various time frames. Refer to the documentation here:
https://www.sierrachart.com/index.php?page=doc/doc_KeyboardCommands.html#Period_ToolBar
but i follow the instructions but in SELECTED TOOLBAR COMMANDS -- SET PERIODS option was there but it was not functional or not in active form. resolve it.
thanks
Date Time Of Last Edit: 2014-07-24 03:43:44
[2014-07-24 07:29:37]
After adding the Custom Bar Period ToolBar command to the Selected ToolBar Command list, you then need to select it in that list and then you can press the Set Period button to customize it.
[2014-07-24 07:43:30]
Refer to the attached image for further detail.
imageCustomChartBarPeriodToolBarButtons.png / V - Attached On 2014-07-24 07:43:27 UTC - Size: 15.29 KB - 343 views
