Date/Time: Thu, 15 Jan 2026 09:25:18 +0000
IB 1 minute data
View Count: 1398
| [2014-07-23 14:59:39] |
| User22153 - Posts: 46 |
Hello Support, I've loaded forex charts for IB and I can get volume for the 1 minute, daily, weekly and monthly. But I can't get volume data for the other timeframes in between? Are there any settings I can change to show this? |
| [2014-07-23 17:08:46] |
Post an image of the chart where you do not see volume. Here are the instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-07-23 17:48:47] |
check out the screenshot
| [2014-07-23 18:01:32] |
For us to help with this we need to see a chart with the standard Sierra Chart "Volume" Study.
| [2014-07-23 19:38:52] |
sure, no problem. See attached.
| [2014-07-23 20:18:50] |
OK we understand the nature of the problem now. The historical data for cash Forex markets from IB will not contain the volume. Instead what you see is a volume of 1 for every underlying data record. You are able to use the historical data from the Sierra Chart Forex data service when using Interactive Brokers. This will be automatically downloaded when using IB Forex symbols. For this you will need to change your service package to 3. Do you want us to do that for you? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-23 20:19:20
