Date/Time: Tue, 09 Jun 2026 15:49:58 +0000
[User Discussion] - Spreadsheet for Trading - issue with Attached Order Quantity
View Count: 821
| [2023-11-13 13:45:47] |
| User347921 - Posts: 39 |
Hello, I've 3 Spreadsheets for Trading, each on a separate graph. All on the same Ticker: MNQ. I've defined Send Order to "NO" on each of these 3 spreadsheets. I've created a fourth Spreadsheet for Trading where the buy signal is OR(BuySystem1, BuySystem2, BuySystem3). Same for Short. I've defined max position as 5 in the 4th Spreadsheet. In the Trade Window, I've defined quantity as 5. The system (#4) takes trades with Stop Loss and Target as expected, but with a Quantity of 1 and not 5. What did I do wrong? How can I make him send orders for 5 instead of 1 please? THANK YOU. |
| Attachment Deleted. |
| [2023-11-13 15:17:28] |
| Sawtooth - Posts: 4333 |
When using the Spreadsheet System for Trading study, the quantity is set in J26, not on the Trade Window.
| [2023-11-13 15:22:51] |
Thank you very much. It works.
| [2023-11-13 15:32:01] |
| Sierra_Chart Engineering - Posts: 23966 |
You need to set the order quantity with this Sheet cell: Spreadsheet Systems, Alerts and Automated Trading: Order Quantity (read / write) [v1:J26, v2:J69] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
