Date/Time: Thu, 10 Jul 2025 02:54:11 +0000
Spreadsheet Data
View Count: 1067
[2014-07-22 08:43:20] |
User94740 - Posts: 333 |
Does the spreadsheet have to be populated first with the data or can I pull on all the data stored in the .scid formatted files?
[2014-07-22 08:57:45] |
This question is not making sense to us. What is it that you want to do?
[2014-07-22 09:38:41] |
i wish to analyze the data. eg determine a statistic for time of day at which the high or low usually occurs
[2014-07-22 16:54:00] |
If you want to use the Spreadsheet study for this, then here is the documentation for the Spreadsheet study: https://www.sierrachart.com/index.php?page=doc/doc_StudiesSystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
