Date/Time: Sun, 05 May 2024 14:24:02 +0000
@ES?## IQFeed continous contracts
View Count: 936
[2014-07-22 03:45:37] |
Todd - Posts: 62 |
I tried setting up a continuous contract for @ESU14 (vol based, back adjusted). But, only the current contract is being referenced. When I do a backfill following the instructions, only U14 is downloaded. The continuous contract prompt is not made. I looked in global symbol settings, and there is nothing under @ES?## for rollover. I updated the symbol settings and still it is blank. Any ideas? |
[2014-07-22 04:36:28] |
We added the correct settings for Rollover for @ES?## for IQ Feed. Follow the instructions here to update the symbol settings: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this follow the instructions here to use the Continuous Futures Contract feature: https://www.sierrachart.com/index.php?page=doc/doc_ContinuousFuturesContractCharts.html#UsingContinuousFuturesContractCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
