Date/Time: Sat, 04 May 2024 16:41:18 +0000
Lines Shimmy
View Count: 1208
[2014-07-22 03:02:49] |
Kiwi - Posts: 374 |
I've got 3 fairly long parallel trend lines (draw one, the other two are copied and moved). When I manually move the chart up and down with interactive scale move the lines shimmy (see the two pictures). Scale automatic or manual; scale linear. Applies to SC version 1154 and 1163. The left most line is the first drawn and its anchors are from the lower bar high to the upper bar high ... notice that the trend line moves slightly above and below the high of the upper bar. http://i.imgur.com/PmzGiDx.png http://i.imgur.com/JUmHIfb.png Date Time Of Last Edit: 2014-07-22 03:09:03
[2014-07-22 03:29:12] |
ganz - Posts: 1048 |
Kiwi Hi FYI: Trend Lines move, when scaling in or out. |
[2014-07-22 05:00:44] |
Kiwi - Posts: 374 |
Thanks ganz, makes sense.
