Date/Time: Sat, 04 May 2024 15:57:08 +0000
[User Discussion] - Programming Work
View Count: 4482
[2014-07-21 12:57:07] |
PhilipJames - Posts: 34 |
Is there anyone here who does programming work in Sierra, who are not already listed on the official page of developers? There's a nice job that needs doing for Rob Booker. Also, what happened to Sock? Cheers! |
[2014-07-27 13:05:09] |
bumping this up in case anyone missed it due to all the new posts and threads which followed
[2014-07-28 06:07:32] |
Kiwi - Posts: 374 |
Under Support / Study and System Programmers http://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.html |
[2014-07-28 06:40:33] |
You may also want to try using odesk.com or Elance.com.
[2014-08-13 15:25:41] |
Thanks for all the info. They have still been unable to find anyone. They tried thelist on the Sierra web page listing programmers, but no luck there. Also tried elance and odesk and neither came up with anyone reliable. The couple that they got had never programmed anything trading related before, not for any platforms, etc and they said they would "give it a try". They did that before with other indicators and the results were "undesirable at best". Is there anyone else here who had programmed Sierra successfully before, who would like to look at it? They are all ready to pay etc, no problem apparently. There are several Sierra users wanting this, and maybe more will subscribe if the indicators are available? (i dont know) Many thanks! Date Time Of Last Edit: 2014-08-13 15:26:17
[2014-08-14 04:29:45] |
The indicators have already been coded on other leading Charts packages now, with Sierra still to be done. So I would imagine it could just be a case of converting existing source code? From a personal point of view, i hope this can be done soon as my annual Sierra subscription is due shortly, and I love Sierra. |
[2014-08-14 23:13:39] |
crazybears - Posts: 314 |
Hi PhilipJames can you post some screenshots of indicators and their formula ? if they aren't too complicated maybe i can try . |
[2014-08-15 05:18:02] |
Thanks, Crazybears. I'm on the wrong device at the moment, but it's mainly central pivots plus divergences. Would you be able to email Wes at rob@tfl365.com? Thanks Crazy! |
[2014-08-16 10:07:48] |
Did you e-mail them ok, Crazy? It's mainly Rob Booker's Knoxville Divergence. Looks quite simple to me. I used to program many years ago, but out of it now. Anyone who has successfully programmed in Sierra previously, and would like to do it... rob@tfl365.com Cheers |
[2014-08-16 10:39:18] |
hello not yet, but be careful i'm not an expert only amateur , although , i try to do the best, i do it for fun . later i send you email. |
[2014-08-16 12:34:28] |
moonmist - Posts: 127 |
Hi, It seems that you need something like D3Spotter by David Anderson: http://www.ninjatrader.com/support/forum/local_links_search.php?action=like&linkid=327&catid=4 You may like to send him an E-mail to get the source codes, and the documentation. IMHO, modification is usually easier than invention. Date Time Of Last Edit: 2014-08-16 12:38:50
[2014-08-19 14:10:31] |
Thanks Crazy. Thanks Moon. They do have this already programmed for a lot of Charting packages, for thousands of users of the indicators. So I suppose it would be just a case of someone adapting one of those to Sierra. Sierra just seems to be the only package where they are having enormous difficulty getting someone to get this simple job done. cheers |
[2014-08-19 18:21:46] |
PTG - Posts: 57 |
Are you looking for this: http://trade29.com/store/sierrachart-2/divergence-detector/
[2014-08-19 19:54:08] |
User021827 - Posts: 174 |
Yea the link by PTG appears to be similar. They also do custom coding for Sierra there at trade29. regards Date Time Of Last Edit: 2014-08-19 19:55:53
[2014-08-23 03:34:14] |
Thanks very much for that, PTG. And thanks user021827. I've sent that info on to rob booker. If anyone has any other links, or offers to do programming themselves, I'll also send on, or you can contact them here rob@tfl365.com Thanks again! |
[2014-12-12 16:27:56] |
PTG - Posts: 57 |
Any developments re. this, PhilipJames and/or others ?
[2014-12-12 16:38:32] |
There has been no-one found to do the work, which is a great shame, as I liked Sierra Charts a lot. So when my annual Sierra membership was due, i couldn't renew it so am no longer a subscriber. If something as simple as this gets sorted out, I would re-subscribe. Great shame. And they are prepared to pay good money to get it done. Probably time to keep moving on - nothing stays the same. cheers |
