Date/Time: Tue, 21 May 2024 05:11:40 +0000
non clr spreadsheets
View Count: 985
[2014-07-18 10:02:57] |
enemyspy - Posts: 304 |
I was looking at the sticky on this, and would be stoked to start using. Are these completely ready to go now? also is there, or going to be a way to convert the old spreadsheets over or will we need to rewrite our systems from the start?
[2014-07-18 11:21:55] |
User33803 - Posts: 40 |
At the sticky you said that the values and formulas will be kept but when I tested the non clr, my values and formulas disappeared.
[2014-07-18 19:36:38] |
The non-CLR spreadsheets are not quite ready for general use. They are still under development We are going to be developing a function to copy the data from the old spreadsheets to the new non-CLR spreadsheets. Currently this does not exist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
