Date/Time: Fri, 17 May 2024 17:38:14 +0000
Some keyboard buttons not working
View Count: 822
[2014-07-17 14:40:02] |
lou_diamonds - Posts: 39 |
When I am typing in a text box on a chart, there are 2 keys that don't work. The keys are the 2 keys to the right of the "0" & ")" key on the numbers row. They are the: "-" & "_" key and the "=" & "+" key What is weird is that they both work when I press shift. So, I can produce "_" & "+", but I can't type a "-" or "=" with these keys. I'm using Windows 7. Do you have any clues to why this is happening & how to fix it? |
[2014-07-17 15:19:24] |
Two things: -Make sure you did not set up keyboard shortcuts using these keys in Global Settings >> customize Keyboard Shortcuts. -Restart Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
