Date/Time: Tue, 21 May 2024 09:06:40 +0000
Back test data
View Count: 931
[2014-07-16 18:05:10] |
User78439 - Posts: 21 |
I need only after hour data in a chart for back test for several months. Which package do I need ? I do not want to buy a data feed as I do not need any real-time data. With Sierra chart data, it is enough for back test ? I need daily, 5m and 15m chart. How long we can do back test with these data ?
[2014-07-16 18:15:17] |
For what symbols do need historical data for? Futures or Forex?
[2014-07-16 18:52:46] |
stock quote, mainly NYSE, NASDAQ and AMex
[2014-07-16 19:18:59] |
You will need Sierra Chart package 3 which includes the Sierra Chart Historical Data Service: https://www.sierrachart.com/index.php?page=doc/SierraChartHistoricalData.html You will get at least 2 years of historical Intraday data for these exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-17 18:31:06] |
You meant that I can get EVENT 1m, 5m and 15m Or daily chart up to 2 years ? If yes, that is great.
[2014-07-17 22:30:29] |
Historical Intraday data is at least 2 years and Historical Daily data is at least 10 years. It also depends upon when a symbol began trading.
[2014-07-18 16:51:39] |
The billing date is the first day of each month or it is 30 day period from the starting date ?
[2014-07-18 17:16:02] |
For each month of usage time purchased, 31 days of usage time are added to existing usage time on your account, if any. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
