Date/Time: Mon, 13 May 2024 18:11:01 +0000
Data into Excel
View Count: 2619
[2014-07-15 17:10:58] |
User62351 - Posts: 3 |
I need to have live data for a symbol go into an excel sheet. I need this in an external excel sheet using EXCEL not the built in sheets in Sierra. How do I do this? Usually in other programs there is a DDE link. Thanks. |
[2014-07-15 18:21:42] |
This can be done using the Spreadsheet study: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html You need to use the Use Excel input: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudyInputs.html#UseExcel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-15 18:22:25
[2014-07-16 17:43:52] |
There is no option on the Global settings>Spreadsheet settings to use excel. as this link describes. |
excel sierra.png / V - Attached On 2014-07-16 17:43:17 UTC - Size: 21.02 KB - 448 views |
[2014-07-16 17:46:41] |
Use Excel is a study input. For instructions to access study inputs, refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-16 18:15:40] |
I added the current price line study to a chart and I don't see the "Use Excel" study input. Its not there. Can you please explain how to get the current price for an instrument to go into Excel. This should be a simple thing and not some complicated process. I cant use the built in excel sheet in sierra because I need this data for a large custom excel sheet I have built. All I need is to get current close data to go into excel. simple. |
excel sierra1.png / V - Attached On 2014-07-16 18:15:17 UTC - Size: 33.46 KB - 446 views excel sierra2.png / V - Attached On 2014-07-16 18:15:26 UTC - Size: 59.12 KB - 401 views |
[2014-07-16 19:23:42] |
The way in which this works is through the Spreadsheet study. Here is the documentation for the Spreadsheet study: https://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetStudy.html It is the Spreadsheet Study that has the Use Excel input. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-12 08:58:21] |
User719206 - Posts: 92 |
i spend my morning to try to find the way to open a study in excell but it was a fail , where is this excell input ?? Impossible to find him
