Date/Time: Tue, 21 Apr 2026 23:21:30 +0000
current price line
View Count: 2620
| [2013-05-03 15:40:29] |
| madra - Posts: 109 |
Hello, The current price line is either way above or below the price column. How do I adjust so that the price line aligns with the price in the column? In all other charts the current price line works perfectly Thank you, charlie http://www.sierrachart.com/image.php?l=1367595347916.png |
| [2013-05-03 22:46:23] |
Make sure the Scale Range Type for the main price graph and studies are set to Automatic. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#ScaleWindow Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
