Date/Time: Sun, 05 May 2024 04:27:59 +0000
Vbp - cumulative delta text
View Count: 1104
[2014-07-14 21:37:36] |
User56254 - Posts: 6 |
Hello, Can you explain me how to fixed the numerix above Vbp => (Total....| Ask vol-Bid vol)?. I send you an image to show you the information that I desired to fixed because this information moved a lot with moved Vbp. http://www.sierrachart.com/image.php?l=1405370991303.png Thank you for your answer. |
[2014-07-15 10:02:49] |
We will look into this.
[2014-07-22 09:31:09] |
We apologize for the delay. This will be resolved in the next release.
