Date/Time: Mon, 29 Apr 2024 03:15:21 +0000
chartbook
View Count: 1831
[2013-05-03 12:34:21] |
UgisDa - Posts: 3 |
cannot open all chartbook
[2013-05-03 13:12:58] |
Do you receive an error message when you try to open a Chartbook? Could you be more specific about the problem.
[2013-05-03 13:54:30] |
UgisDa - Posts: 3 |
Hi! There is a message - The Chartbook file is not valid Chartbook. File: file location |
[2013-05-03 14:52:28] |
Please follow the instructions here to access a backup Chartbook File: http://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-05-03 15:16:42] |
UgisDa - Posts: 3 |
Thanks!
