Date/Time: Tue, 14 May 2024 07:42:27 +0000
Account balance difference between different sources
View Count: 1064
[2014-07-14 09:44:00] |
User25311 - Posts: 30 |
Hi 1-I started with a 6.000€ account (I started with FXCM broker and Sierra Chart at same time. And I have no traded with other software, only with SC) 2-After trades, the "Trades" tab in "Trade Activity Log" window show a 7,30€ "Cum P/L" in the last trade 3-In the "Cash Balance" cell of the "Balance" tab of the "Orders and Positions" window I have a 6.000,8€ cash balance. 4-In my broker report I have a 6.064€ balance *I have never used the simulated trading functionality Why happens? And, how can I solve that? |
[2014-07-14 09:51:22] |
2. What is the symbol you are trading? The Profit/Loss may be in a different currency. Refer to this help topic: https://www.sierrachart.com/index.php?page=helpdetails77.html In the case of Forex trading, the Profit/Loss currency will be the last three characters of the symbol. 3. Do you see this same balance after you select File >> Disconnect and File >> Connect to Data Feed ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-14 10:56:19] |
Well, the difference beetwin FXCM account report and Sierra Chart "Cash Balance" tab is solved. THANKS. But, nonetheless, the "Cump P/L" of the Trade Log is showing 7,30 yet (and thats incorrect). I think is possible that it has an explanation in the image I attached. In that image we can see there is an open position in XAUUSD, but I already closed it (and if I look at the "Positions" tab I confirm it...). ¿? Thanks Date Time Of Last Edit: 2014-07-14 11:02:31
Private File Private File Attachment Deleted. Private File |
[2014-07-14 14:11:46] |
The incorrect Trade Position Open Quantity you see is only on the Trade Stats for Charts tab and that is possible to be inaccurate due to incomplete or inaccurate fill data. For documentation for that tab and how to clear the Trade Activity data to reset the position back to zero, refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#ChartTradeStatsTab Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
