Date/Time: Wed, 15 May 2024 14:35:12 +0000
Config for chart graphics setting
View Count: 870
[2014-07-14 01:36:03] |
User17064 - Posts: 70 |
Hi SC support, Is there any possible to add chart graphics setting config function? Like drawing config, I could select different profile for my chart. If these config could also save with bar type(candle,renko,bar...etc), that will be great |
[2014-07-14 02:56:50] |
No. This is not supported.
[2014-07-14 09:27:42] |
Is that possible to add this function?
[2014-07-14 09:46:13] |
It is unlikely this would be added.
