Date/Time: Wed, 15 May 2024 22:48:56 +0000
[User Discussion] - Time Blocks for the overnight session
View Count: 1899
[2014-07-13 17:47:52] |
User30616 - Posts: 2 |
Is there a way to use the Time Range Highlight-Transparencies to make Time Blocks on the overnignt session? At the moment I use the rectangle tool to creat the time blocks and the Type Text tool to put the market close data in the blocks. http://www.allstocks.com/markets/World_Charts/world_charts.html I click on Yahoo link on the chart to get the market close data the example is the DAX http://finance.yahoo.com/q?s=^GDAXI&d=t If I could shorten the Time Range Highlight-Trtansparencie rather than have them fill up the entire chart for the range I have selected, I think that would work. The other thing I am working on is Range blocks for the overnight session but for now I can do that by hand If you scroll to the left on the chart you can see some samples. Overnignt Range blocks. This came about after reading a article by Brett Steenbarger on Reconizing the Stock Market's Overnight Range. http://traderfeed.blogspot.com/2009/02/understanding-stock-markets-overnight.html On the Market Turn Times and overnight session I only use the Time Range Highlight-Trtansparencie It works great but there is a black screen from the current candle to the next time period I can live with that. Thanks again Sierra Support. http://www.sierrachart.com/image.php?l=1405272075169.png Ian Busey |
[2014-07-15 10:11:19] |
This post is outside the scope of our support. This is a very advanced usage question and it's hard to understand exactly what you are looking for. You also have references to outside sources of information. Unless we have a very good reason to be looking at those, we cannot take the time to be looking at those. It sounds like you need to create your own custom version of Time Range Highlight study. Refer to this page: https://www.sierrachart.com/index.php?page=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-15 10:12:26
