Date/Time: Wed, 17 Dec 2025 07:21:25 +0000
Bid / Offer Missing from DOM
View Count: 587
| [2023-08-22 11:58:03] |
| Justin Taft - Posts: 6 |
Hello, I have been struggling with trying to get the BID and OFFER quantities to show in my DOM. They were there and working fine, however when I went into the Trade / Customize Chart/Trade DOM Columns, I had a blank row that I simply removed and now I can no longer see the numbers. The Blank column I removed was called Label Column, however adding it back does not fix the problem. Any tips on how I can get these numbers back? |
| [2023-08-22 15:37:47] |
| John - SC Support - Posts: 43500 |
Select "Trade >> Customize Chart/Trade DOM Columns". Make sure the columns that are displayed at those locations are either the "Bid/Ask Size" or the "Bid/Ask Buy/Sell Column". These will give you the Market Depth information. The "Buy/Sell" columns do not display the information, they just allow for orders to be placed in those columns. Refer to the following for more on this topic: Global Trade Settings Windows: Buy Order Column - Left/Center/Right Aligned For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
