Date/Time: Sat, 12 Jul 2025 07:14:32 +0000
15 minute opening range breakout and a gap fill range as well
View Count: 915
[2023-08-21 18:12:54] |
User904644 - Posts: 10 |
I cannot figure how to set this up on my charts. I think I am not looking for the proper term? I want to set up a 15 minute opening range breakout technical lines on my chart. I am also looking to find the closing of the price difference from the previous trading day. Both of these are based on the RTHs time frame.
[2023-08-21 18:15:17] |
John - SC Support - Posts: 40857 |
You can find the Opening Range and extend the lines by using the "High/Low for Time Period - Extended". Refer to the following: High/Low for Time Period - Extended We are not sure what you want to compare in terms of the Price Difference from the previous day. But refer to the following study to see if this does what you want: Percent Change Since Previous Close For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
