Date/Time: Sun, 19 May 2024 00:29:29 +0000
Full Compatibility With Mac OS
View Count: 1579
[2014-07-11 20:59:36] |
ged - Posts: 233 |
I noticed in some of your documentation that you anticipated SC becoming fully Mac OS compatible sometime "in 2014". At this point, can you narrow down when SC's Mac OS compatibility may become a reality? Thanks much. |
[2014-07-11 21:38:03] |
We will not be completing this until 2015.
[2015-01-22 18:17:48] |
ged - Posts: 233 |
Is it still planned to achieve Mac OS compatibility this year? If so, does it look like it will occur in the first half of the year or the 2nd half? |
[2015-01-23 03:06:43] |
It may happen this year, but certainly not the first or the second half. More than likely it will be sometime in 2016.
