Date/Time: Mon, 30 Jun 2025 19:53:32 +0000
How to copy my backtest order to another computer?
View Count: 478
[2023-08-19 10:47:56] |
rfmlinux - Posts: 2 |
I want to copy copy my backtest order to another PC. But I just want to copy the order within the scope of chartbook. Is there a way to do this? I successed to copy chartbook to another PC with *.cht data. But It just copy the mark I made on the chart and the range of backtest chart. |
[2023-08-20 14:44:59] |
Sierra_Chart Engineering - Posts: 20024 |
Do you mean the order fills or open orders? Or both? Order fill data would be contained within the TradeActivityLogs subfolder. You can copy the corresponding files within that folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-22 14:42:50] |
I want to see my backtest order fills history in my chartbook when I enable "Trade->Show Order Fills"(Ctrl+Shift+O). Like the picture below. I have tried export file from "Trade->Trade Activity Log". And copy .txt data to another PC then open "Trade->Trade Activity Log" to import .txt data. But it didn't work. The Trade Service Log just show "Read 0 non-simulated fills, and simulated fills from the file XXXXXXX". |
[2023-08-22 22:08:29] |
You need to go to the TradeActivityLogs subfolder in the Sierra Chart installation folder and copy the files for the particular Symbol and Trade Account and trade dates, that you want to copy to the other installation of Sierra Chart, to that other installation.
