Date/Time: Sat, 05 Sep 2026 17:20:12 +0000
Chart Value / Tool Value windows showing unknown items
View Count: 856
[2023-08-18 23:21:34]
OliviaKim - Posts: 6
I know how to select or remove chart value data in vlaue windows, but I can't remove those printed in gray color. It seems daily candle data.
How can I remove them?
Thanks.
https://www.sierrachart.com/image.php?Image=1692400826846.png
imageScreenshot 2023-08-18 170308.jpg / V - Attached On 2023-08-18 23:04:03 UTC - Size: 36.22 KB - 271 views
[2023-08-21 14:51:55]
John - SC Support - Posts: 47793
Refer to the following:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#ChartValuesSettings
[2023-08-22 16:03:17]
I already scrutinized that part but there is nothing explained on those gray colored values and how to remove them. Where are those from?
As you can see, I removed volume and other values related averages except HL avg from the chart value window, still removed values are showing up in gray color and gray numbers are not matching to white colored values. Seems it copies from different chart, but I can't figure it out where exactly, and how to remove them.
Date Time Of Last Edit: 2023-08-22 17:38:13
[2023-08-22 17:37:07]
Sorry, apparently we have a bad link. Here is the correct link for what you are wanting:
Chart Settings: Chart Values Field Settings (Button) (Chart >> Chart Settings >> Display >> Chart Values menu)
[2023-08-22 17:41:41]
Thanks for the new link, but I already read through it, and managing other charts according to it, except this chart.
Do you have any idea where those gray colored lines are from?
[2023-08-22 18:16:03]
Please get us a copy of the chart so we can take a look. Follow these instructions to do this:
[2023-08-22 20:32:14]
While removing studies one by one to create upload file, I discovered the study that pushed the extra value printed in the value window. I configured them properly and resolved my problem.
Thank you for your follow up!!
