Date/Time: Fri, 10 May 2024 19:40:10 +0000
Rithmic account rounting
View Count: 290
[2023-08-09 02:39:47] |
User653970 - Posts: 38 |
Hi, I understand that Sierra Chart team does not like Rithmic but unfortunately, I have to use evaluation funds that place accounts on Rithmic. With that being said, I'd like to understand how Sierra Chart handle trading request with Rithmic accounts. Is it directly from my PC running Sierra Chart and go straight to Rithmic server based on the gateway location I picked? I'm using SC Data Feed for data, and where is this data center location? I would like to create some sort of high speed scalping by running my bot in parallel with Sierra Chart for data and order execution rather than doing from raw API and C#. Thanks |
[2023-08-09 13:56:59] |
John - SC Support - Posts: 31533 |
Yes. For more specific information, you would have to check with Rithmic I'm using SC Data Feed for data, and where is this data center location?
It is in the data center with the CME Group in Chicago. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-08-09 18:59:39] |
Perfect, thank you very much as always. Very quick response.
