Date/Time: Tue, 14 May 2024 15:05:55 +0000
Как добиться отображения данной Гистограммы см. скр
View Count: 1050
[2014-07-09 17:49:02] |
User10686 - Posts: 2 |
Как добиться отображения данной Гистограммы см. скрин. |
Attachment Deleted. |
[2014-07-10 05:57:55] |
This is known as the DOM Graph. Here is the documentation to use this feature: https://www.sierrachart.com/index.php?page=doc/doc_TradeMenu.html#DrawDOMGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-14 09:50:48] |
Thanks for the answer
