Date/Time: Wed, 01 May 2024 23:55:29 +0000
swing high and low study problem
View Count: 2063
[2013-05-02 23:10:38] |
joer - Posts: 41 |
I am trying to use the swing high and low study with flex renko bars in a spreadsheet study. The problem is that the value for the swing high or low does not match the high or low in column c or d, and it does not match the open or close value from the new renko open/close study. For example, for a particular bar that was a swing high, the swing high value in the study is 448.3315, the high for the bar in column c is 448.28, and the values in the renko visual open/close don't match either one because it was a down bar with a tail above the open.
[2013-05-03 00:33:02] |
N!co - Posts: 140 |
Have a look at the study called "Renko Visual Open/Close Values" see if that helps |
[2013-05-03 03:28:53] |
joer - Posts: 41 |
As I said in my initial request, "...and it does not match the open or close value from the new renko open/close study".
[2013-05-03 04:09:42] |
This has an easy solution. Set the Arrow Offset input to 0 in the study.
