Date/Time: Sat, 27 Apr 2024 17:30:46 +0000
Error connecting to CTS FIX
View Count: 1023
[2014-07-04 06:50:44] |
Dom7364 - Posts: 257 |
Please see below. Itiinitially connects then doesn't download anything. Anything I have to do? Thanks Software version: 1156 | 2014-07-04 08:11:54 Usage end date: 2014-07-31 | 2014-07-04 08:11:54 Enabled for: Advanced Features. | 2014-07-04 08:11:54 Enabled for: Advanced Features 2. | 2014-07-04 08:11:54 Enabled for: Sierra Chart Historical Data Service. | 2014-07-04 08:11:54 Allow Support for Sierra Chart Data Feeds is enabled. | 2014-07-04 08:11:54 Active service: Rithmic Trading | 2014-07-04 08:11:54 Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2014-07-04 08:11:54 2014-07-04 08:11:54 Local computer clock time | 2014-07-04 08:11:54 2014-07-04 06:11:54 GMT time | 2014-07-04 08:11:54 2014-07-04 08:11:54 Time zone adjusted time | 2014-07-04 08:11:54 Time difference to server time: 2 seconds. | 2014-07-04 08:11:54 Program path: C:\SierraChart\ | 2014-07-04 08:11:54 Data Files path: C:\SierraChart\Data\ | 2014-07-04 08:11:54 OS Version Number: 6.2 | 2014-07-04 08:11:54 Checking for new symbol settings for rim | 2014-07-04 08:11:54 Requesting symbol settings for rim. Overwrite = on. | 2014-07-04 08:11:55 Symbol settings received. | 2014-07-04 08:11:56 Processed received symbol settings | 2014-07-04 08:11:56 Rithmic Trading - Port for executable: 50881 | 2014-07-04 08:11:59 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-07-04 08:11:59 Rithmic Trading: Connecting to the server 127.0.0.1. Port 50881 | 2014-07-04 08:12:01 Socket (2120) - Connected. | 2014-07-04 08:12:01 Rithmic Trading: Connected to server. | 2014-07-04 08:12:01 Rithmic Trading: Sending logon request message. | 2014-07-04 08:12:01 Rithmic Trading | Starting the connection process to data and trading service. | 2014-07-04 08:12:01 Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-07-04 08:12:01 Rithmic Trading | Connecting to Rithmic 01 Europe server. | 2014-07-04 08:12:01 Rithmic Trading | Server Alert: Market Data Connection Broken | 2014-07-04 08:12:03 Rithmic Trading | Server Alert: Trading System Connection Broken | 2014-07-04 08:12:04 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-07-04 08:12:05 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-07-04 08:12:05 Rithmic Trading Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-07-04 08:12:05 Rithmic Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-04 08:12:05 Rithmic Trading - Logon error from server | 2014-07-04 08:12:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:05 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:05 Socket (2120) - Shutdown and closed. | 2014-07-04 08:12:05 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:05 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:05 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:12:07 Rithmic Trading: Connecting to the server 127.0.0.1. Port 50881 | 2014-07-04 08:12:09 Socket (2120) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:12:10 Socket (2120) - Shutdown and closed. | 2014-07-04 08:12:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:10 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:10 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:10 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:10 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:12:12 Rithmic Trading: Connecting to the server 127.0.0.1. Port 50881 | 2014-07-04 08:12:14 Socket (2120) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:12:15 Socket (2120) - Shutdown and closed. | 2014-07-04 08:12:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:15 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:15 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:15 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:15 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:12:17 Rithmic Trading: Connecting to the server 127.0.0.1. Port 50881 | 2014-07-04 08:12:19 Socket (2136) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:12:20 Socket (2136) - Shutdown and closed. | 2014-07-04 08:12:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:20 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:20 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:20 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:12:22 Rithmic Trading: Connecting to the server 127.0.0.1. Port 50881 | 2014-07-04 08:12:24 Socket (400) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:12:25 Socket (400) - Shutdown and closed. | 2014-07-04 08:12:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:25 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:25 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:25 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:25 Rithmic Trading - Port for executable: 57281 | 2014-07-04 08:12:27 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-07-04 08:12:27 Rithmic Trading: Connecting to the server 127.0.0.1. Port 57281 | 2014-07-04 08:12:29 Socket (2128) - Connected. | 2014-07-04 08:12:29 Rithmic Trading: Connected to server. | 2014-07-04 08:12:29 Rithmic Trading: Sending logon request message. | 2014-07-04 08:12:29 Rithmic Trading | Starting the connection process to data and trading service. | 2014-07-04 08:12:29 Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-07-04 08:12:29 Rithmic Trading | Connecting to Rithmic 01 Europe server. | 2014-07-04 08:12:29 Rithmic Trading | Server Alert: Market Data Connection Broken | 2014-07-04 08:12:31 Rithmic Trading | Server Alert: Trading System Connection Broken | 2014-07-04 08:12:32 Rithmic Trading | Server Alert: PnL Connection Opened | 2014-07-04 08:12:33 Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-07-04 08:12:33 Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2014-07-04 08:12:33 Rithmic Trading Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-07-04 08:12:33 Rithmic Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-04 08:12:33 Rithmic Trading - Logon error from server | 2014-07-04 08:12:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:33 Socket (2128) - Shutdown and closed. | 2014-07-04 08:12:33 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:33 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:33 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:12:35 Rithmic Trading: Connecting to the server 127.0.0.1. Port 57281 | 2014-07-04 08:12:37 Socket (2128) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:12:38 Socket (2128) - Shutdown and closed. | 2014-07-04 08:12:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:38 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:38 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:38 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:12:40 Rithmic Trading: Connecting to the server 127.0.0.1. Port 57281 | 2014-07-04 08:12:42 Socket (1296) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:12:43 Socket (1296) - Shutdown and closed. | 2014-07-04 08:12:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:43 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:43 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:43 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:12:45 Rithmic Trading: Connecting to the server 127.0.0.1. Port 57281 | 2014-07-04 08:12:47 Socket (2072) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:12:48 Socket (2072) - Shutdown and closed. | 2014-07-04 08:12:48 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:48 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:48 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:48 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:12:50 Rithmic Trading: Connecting to the server 127.0.0.1. Port 57281 | 2014-07-04 08:12:52 Socket (2072) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:12:53 Socket (2072) - Shutdown and closed. | 2014-07-04 08:12:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:12:53 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:12:53 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:12:53 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:12:53 Rithmic Trading - Port for executable: 62401 | 2014-07-04 08:12:55 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-07-04 08:12:55 Rithmic Trading: Connecting to the server 127.0.0.1. Port 62401 | 2014-07-04 08:12:57 Socket (2172) - Connected. | 2014-07-04 08:12:57 Rithmic Trading: Connected to server. | 2014-07-04 08:12:57 Rithmic Trading: Sending logon request message. | 2014-07-04 08:12:57 Rithmic Trading | Starting the connection process to data and trading service. | 2014-07-04 08:12:57 Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-07-04 08:12:57 Rithmic Trading | Connecting to Rithmic 01 Europe server. | 2014-07-04 08:12:57 Rithmic Trading | Server Alert: Market Data Connection Broken | 2014-07-04 08:12:59 Rithmic Trading | Server Alert: Trading System Connection Broken | 2014-07-04 08:13:00 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-07-04 08:13:00 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-07-04 08:13:01 Rithmic Trading Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-07-04 08:13:01 Rithmic Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-04 08:13:01 Rithmic Trading - Logon error from server | 2014-07-04 08:13:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:01 Socket (2172) - Shutdown and closed. | 2014-07-04 08:13:01 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:01 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:01 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:03 Rithmic Trading: Connecting to the server 127.0.0.1. Port 62401 | 2014-07-04 08:13:05 Socket (796) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:06 Socket (796) - Shutdown and closed. | 2014-07-04 08:13:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:06 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:06 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:06 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:08 Rithmic Trading: Connecting to the server 127.0.0.1. Port 62401 | 2014-07-04 08:13:10 Socket (2072) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:11 Socket (2072) - Shutdown and closed. | 2014-07-04 08:13:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:11 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:11 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:11 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:13 Rithmic Trading: Connecting to the server 127.0.0.1. Port 62401 | 2014-07-04 08:13:15 Socket (1376) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:16 Socket (1376) - Shutdown and closed. | 2014-07-04 08:13:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:16 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:16 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:16 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:18 Rithmic Trading: Connecting to the server 127.0.0.1. Port 62401 | 2014-07-04 08:13:20 Socket (1372) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:21 Socket (1372) - Shutdown and closed. | 2014-07-04 08:13:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:21 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:21 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:21 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:21 Rithmic Trading - Port for executable: 3010 | 2014-07-04 08:13:23 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-07-04 08:13:23 Rithmic Trading: Connecting to the server 127.0.0.1. Port 3010 | 2014-07-04 08:13:25 Socket (2176) - Connected. | 2014-07-04 08:13:25 Rithmic Trading: Connected to server. | 2014-07-04 08:13:25 Rithmic Trading: Sending logon request message. | 2014-07-04 08:13:25 Rithmic Trading | Starting the connection process to data and trading service. | 2014-07-04 08:13:25 Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-07-04 08:13:25 Rithmic Trading | Connecting to Rithmic 01 Europe server. | 2014-07-04 08:13:25 Rithmic Trading | Server Alert: Market Data Connection Broken | 2014-07-04 08:13:27 Rithmic Trading | Server Alert: Trading System Connection Broken | 2014-07-04 08:13:28 Rithmic Trading | Server Alert: PnL Connection Opened | 2014-07-04 08:13:29 Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-07-04 08:13:29 Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2014-07-04 08:13:29 Rithmic Trading Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-07-04 08:13:29 Rithmic Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-04 08:13:29 Rithmic Trading - Logon error from server | 2014-07-04 08:13:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:29 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:29 Socket (2176) - Shutdown and closed. | 2014-07-04 08:13:29 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:29 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:29 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:31 Rithmic Trading: Connecting to the server 127.0.0.1. Port 3010 | 2014-07-04 08:13:33 Socket (1240) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:34 Socket (1240) - Shutdown and closed. | 2014-07-04 08:13:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:34 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:34 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:34 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:34 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:36 Rithmic Trading: Connecting to the server 127.0.0.1. Port 3010 | 2014-07-04 08:13:38 Socket (1372) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:39 Socket (1372) - Shutdown and closed. | 2014-07-04 08:13:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:39 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:39 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:39 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:41 Rithmic Trading: Connecting to the server 127.0.0.1. Port 3010 | 2014-07-04 08:13:43 Socket (1124) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:44 Socket (1124) - Shutdown and closed. | 2014-07-04 08:13:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:44 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:44 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:44 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:46 Rithmic Trading: Connecting to the server 127.0.0.1. Port 3010 | 2014-07-04 08:13:48 Socket (1372) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:49 Socket (1372) - Shutdown and closed. | 2014-07-04 08:13:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:49 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:49 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:49 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:13:51 Rithmic Trading: Connecting to the server 127.0.0.1. Port 3010 | 2014-07-04 08:13:53 Socket (1372) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:13:54 Socket (1372) - Shutdown and closed. | 2014-07-04 08:13:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:13:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:13:54 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:13:54 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:13:54 Rithmic Trading - Port for executable: 21186 | 2014-07-04 08:13:56 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-07-04 08:13:56 Rithmic Trading: Connecting to the server 127.0.0.1. Port 21186 | 2014-07-04 08:13:58 Socket (2164) - Connected. | 2014-07-04 08:13:58 Rithmic Trading: Connected to server. | 2014-07-04 08:13:58 Rithmic Trading: Sending logon request message. | 2014-07-04 08:13:58 Rithmic Trading | Starting the connection process to data and trading service. | 2014-07-04 08:13:58 Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-07-04 08:13:58 Rithmic Trading | Connecting to Rithmic 01 Europe server. | 2014-07-04 08:13:58 Rithmic Trading | Server Alert: Market Data Connection Broken | 2014-07-04 08:14:00 Rithmic Trading | Server Alert: Trading System Connection Broken | 2014-07-04 08:14:01 Rithmic Trading | Server Alert: Market Data Connection Opened | 2014-07-04 08:14:01 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-07-04 08:14:02 Rithmic Trading Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-07-04 08:14:02 Rithmic Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-04 08:14:02 Rithmic Trading - Logon error from server | 2014-07-04 08:14:02 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:02 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:02 Socket (2164) - Shutdown and closed. | 2014-07-04 08:14:02 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:02 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:02 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:14:04 Rithmic Trading: Connecting to the server 127.0.0.1. Port 21186 | 2014-07-04 08:14:06 Socket (1268) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:14:07 Socket (1268) - Shutdown and closed. | 2014-07-04 08:14:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:07 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:07 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:07 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:07 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:14:09 Rithmic Trading: Connecting to the server 127.0.0.1. Port 21186 | 2014-07-04 08:14:11 Socket (1120) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:14:12 Socket (1120) - Shutdown and closed. | 2014-07-04 08:14:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:12 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:12 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:12 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:14:14 Rithmic Trading: Connecting to the server 127.0.0.1. Port 21186 | 2014-07-04 08:14:16 Socket (1120) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:14:17 Socket (1120) - Shutdown and closed. | 2014-07-04 08:14:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:17 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:17 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:17 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:17 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:14:19 Rithmic Trading: Connecting to the server 127.0.0.1. Port 21186 | 2014-07-04 08:14:21 Socket (2184) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:14:22 Socket (2184) - Shutdown and closed. | 2014-07-04 08:14:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:22 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:22 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:22 Rithmic Trading - Port for executable: 28098 | 2014-07-04 08:14:24 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-07-04 08:14:24 Rithmic Trading: Connecting to the server 127.0.0.1. Port 28098 | 2014-07-04 08:14:26 Socket (1276) - Connected. | 2014-07-04 08:14:26 Rithmic Trading: Connected to server. | 2014-07-04 08:14:26 Rithmic Trading: Sending logon request message. | 2014-07-04 08:14:26 Rithmic Trading | Starting the connection process to data and trading service. | 2014-07-04 08:14:26 Rithmic Trading | Logging is enabled. Log file: Rithmic.log | 2014-07-04 08:14:26 Rithmic Trading | Connecting to Rithmic 01 Europe server. | 2014-07-04 08:14:26 Rithmic Trading | Server Alert: Market Data Connection Broken | 2014-07-04 08:14:28 Rithmic Trading | Server Alert: Trading System Connection Broken | 2014-07-04 08:14:28 Rithmic Trading | Server Alert: PnL Connection Opened | 2014-07-04 08:14:29 Rithmic Trading | Server Alert: Trading System Connection Opened | 2014-07-04 08:14:29 Rithmic Trading | Server Alert: PnL Connection Login Failed. Result text: "permission denied" | 2014-07-04 08:14:30 Rithmic Trading Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-07-04 08:14:30 Rithmic Trading - Server protocol version: 4. Client protocol version: 4. There is a protocol match. | 2014-07-04 08:14:30 Rithmic Trading - Logon error from server | 2014-07-04 08:14:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:30 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:30 Socket (1276) - Shutdown and closed. | 2014-07-04 08:14:30 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:30 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:30 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:14:32 Rithmic Trading: Connecting to the server 127.0.0.1. Port 28098 | 2014-07-04 08:14:34 Socket (1276) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:14:35 Socket (1276) - Shutdown and closed. | 2014-07-04 08:14:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:35 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:35 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:35 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:14:37 Rithmic Trading: Connecting to the server 127.0.0.1. Port 28098 | 2014-07-04 08:14:39 Socket (1276) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:14:40 Socket (1276) - Shutdown and closed. | 2014-07-04 08:14:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:40 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:40 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:40 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:40 Rithmic Trading: Bridge process is still running. | 2014-07-04 08:14:42 Rithmic Trading: Connecting to the server 127.0.0.1. Port 28098 | 2014-07-04 08:14:44 Socket (2176) - Error received in OnConnect while connecting. Windows error code 10061: Aucune connexion n’a pu être établie car l’ordinateur cible l’a expressément refusée. | 2014-07-04 08:14:45 Socket (2176) - Shutdown and closed. | 2014-07-04 08:14:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-07-04 08:14:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-07-04 08:14:45 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:14:45 Will reconnect to the server in 3.0 minutes Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:14:45 File >> Disconnect selected. | 2014-07-04 08:16:38 Rithmic Trading: Disconnected from the server. | 2014-07-04 08:16:38 Current selected Data/Trading service: CTS T4 FIX | 2014-07-04 08:45:38 Checking for new symbol settings for cts | 2014-07-04 08:45:38 Requesting symbol settings for cts. Overwrite = on. | 2014-07-04 08:45:39 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-07-04 08:45:41 CTS FIX - Firm: Dorman | 2014-07-04 08:45:41 CTS FIX socket (0) - Resolved address fix-sim.t4login.com to IP 69.44.110.200 | 2014-07-04 08:45:45 Symbol settings received. | 2014-07-04 08:45:46 Processed received symbol settings | 2014-07-04 08:45:46 CTS FIX socket (1268) - Connected. | 2014-07-04 08:45:46 CTS FIX socket (1268) - Starting SSL connection. | 2014-07-04 08:45:46 CTS FIX socket (1268) - SSL connection established. | 2014-07-04 08:45:48 CTS FIX: Sending the Logon message. | 2014-07-04 08:45:48 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-07-04 08:45:48 CTS FIX: Received Account List collateral report. | 2014-07-04 08:45:48 CTS FIX: Subscribing to account: DT* | 2014-07-04 08:45:48 CTS FIX: Received Account Update collateral report. | 2014-07-04 08:45:50 @EUU14 [CV] 5000 Volume #1: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:53 @EUU14 [CV] 5000 Volume #1: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:53 @EUU14 [CV] 0.0004 Range #6: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:53 @EUU14 [CV] 0.0004 Range #6: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:53 @EUU14 [CBV] 0.0004 Range #5: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:53 @EUU14 [CBV] 0.0004 Range #5: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:53 @EUU14 [CBV] #8: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:53 @EUU14 [CBV] #8: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:53 @EUU14 [CBV] #9: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:53 @EUU14 [CBV] #9: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:53 @EUU14 [CBV] #11: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:53 @EUU14 [CBV] #11: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:53 @EUU14 [CB] 20000 Volume #12: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:53 @EUU14 [CB] 20000 Volume #12: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:53 @EUU14 [CBV] 10000 Volume #13: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:53 @EUU14 [CBV] 10000 Volume #13: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:53 @EUU14 [CV] 5000 Volume #7: Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2014-07-04 08:45:55 @EUU14 [CV] 5000 Volume #7: There are no continuous futures contracts symbols. Loading data normally. | 2014-07-04 08:45:55 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:45:57 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:45:58 CTS T4 FIX - Starting real-time market data updates for: @EUU14. ID: 1 | 2014-07-04 08:45:58 Symbol Error - @EUU14 is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:45:58 HD Request # 2 - Downloading Intraday chart data for @EUU14 to the file @EUU14.scid. Service: cts | 2014-07-04 08:45:59 HD Request # 2 - Download start Date-Time: 2014-07-03 18:49:20.0 | 2014-07-04 08:45:59 HD Request # 2 - Error downloading historical Intraday data for @EUU14. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:45:59 HD Request # 2 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @EUU14 | 2014-07-04 08:45:59 HD Request # 2 - Intraday download COMPLETE for @EUU14. Completion time: 0s | 2014-07-04 08:45:59 Real-time Intraday chart data file updates started for @EUU14 | 2014-07-04 08:45:59 CTS FIX: Requesting Open Orders for account: DT* | 2014-07-04 08:45:59 Requesting market depth updates for: @EUU14 if supported. | 2014-07-04 08:45:59 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:45:59 CTS T4 FIX - Starting real-time market data updates for: TICK.Z. ID: 2 | 2014-07-04 08:46:00 Symbol Error - TICK.Z is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:46:00 HD Request # 3 - Downloading Intraday chart data for TICK.Z to the file TICK.Z.scid. Service: cts | 2014-07-04 08:46:00 HD Request # 3 - Download start Date-Time: 2014-07-03 18:49:32.0 | 2014-07-04 08:46:00 HD Request # 3 - Error downloading historical Intraday data for TICK.Z. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:46:00 HD Request # 3 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK.Z | 2014-07-04 08:46:00 HD Request # 3 - Intraday download COMPLETE for TICK.Z. Completion time: 0s | 2014-07-04 08:46:00 Real-time Intraday chart data file updates started for TICK.Z | 2014-07-04 08:46:00 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: Monsetup.cht | 2014-07-04 08:46:00 CTS FIX: Received Account List collateral report. | 2014-07-04 08:46:00 Chart #4 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:46:00 Chart #1 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:46:00 Chart #2 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:46:00 Chart #2 has tagged chart #6 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:46:00 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: Monsetup.cht | 2014-07-04 08:46:00 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: Monsetup.cht | 2014-07-04 08:46:00 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:46:00 Chart #5 is performing a full recalculation because it has been tagged. Chartbook: Monsetup.cht | 2014-07-04 08:46:01 CTS FIX: Received Account List collateral report. | 2014-07-04 08:46:04 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16. | 2014-07-04 08:46:34 Date rule based rollover from 6E.20140900.CME_Fo to next contract occurs at 2014-09-15. | 2014-07-04 08:46:34 Checking Intraday data file for symbol 6E.20140600.CME_Fo for the date range from 2014-03-17 to 2014-06-16. | 2014-07-04 08:46:34 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 2014-06-16. | 2014-07-04 08:46:34 Intraday data file for 6E.20140900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-07-04 08:46:34 Checking Daily data file for symbol E6U14 for the date range from 2014-06-16 to 0. | 2014-07-04 08:46:34 Symbols used for 6E.20140900.CME_Fo continuous contract chart: | 2014-07-04 08:46:34 6E.20140600.CME_Fo | 2014-07-04 08:46:34 6E.20140900.CME_Fo | 2014-07-04 08:46:34 HD Request # 4 - Downloading Intraday chart data for 6E.20140600.CME_Fo to the file 6E.20140600.CME_Fo.scid. Service: cme | 2014-07-04 08:46:34 Compressing file: C:\SierraChart\Data\6E.20140600.CME_Fo.scid. This may take a while... | 2014-07-04 08:46:34 HD Request # 4 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:46:34 HD Request # 4 - Download start Date-Time: 2014-03-15 01:00:00.0 | 2014-07-04 08:46:34 HD Request # 4 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:46:34 HD Request # 4 - Using server: scdf1.sierracharts.com port 10149 | 2014-07-04 08:46:34 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-07-04 08:46:34 Socket (3028) - Connected. | 2014-07-04 08:46:34 HD Request # 4 - Sending historical data logon request message. | 2014-07-04 08:46:34 HD Request # 4 - Requesting Intraday data. Start Date-Time: 2014-03-15 01:00:00. Record interval: 60. Symbol: 6EM4 | 2014-07-04 08:46:35 HD Request # 4 - Decompressing data. | 2014-07-04 08:46:35 HD Request # 4 - Receiving Intraday data for 6E.20140600.CME_Fo starting at 2014-03-16 23:00:00 | 2014-07-04 08:46:35 HD Request # 4 - Timestamp of first Intraday data file record written: 2014-03-16 23:00:00 | 2014-07-04 08:46:35 Socket (3028) - Shutdown and closed. | 2014-07-04 08:46:45 The network socket for historical data has been closed. | 2014-07-04 08:46:45 HD Request # 4 - Received 78598 records from 2014-03-16 23:00:00 to 2014-06-16 16:06:07 (91.7 days) and wrote 78598 records for 6E.20140600.CME_Fo | 2014-07-04 08:46:45 HD Request # 4 - Intraday download COMPLETE for 6E.20140600.CME_Fo. Completion time: 11s | 2014-07-04 08:46:45 HD Request # 5 - Downloading Intraday chart data for 6E.20140600.CME_Fo to the file 6E.20140600.CME_Fo.scid. Service: cme | 2014-07-04 08:46:45 HD Request # 5 - Download start Date-Time: 2014-03-15 01:00:00.0 | 2014-07-04 08:46:45 HD Request # 5 - Using server: scdf2.sierracharts.com port 10149 | 2014-07-04 08:46:45 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-07-04 08:46:45 Socket (3040) - Connected. | 2014-07-04 08:46:45 HD Request # 5 - Sending historical data logon request message. | 2014-07-04 08:46:45 HD Request # 5 - Requesting Intraday data. Start Date-Time: 2014-03-15 01:00:00. Record interval: 0. Symbol: 6EM4 | 2014-07-04 08:46:46 HD Request # 5 - Decompressing data. | 2014-07-04 08:46:46 HD Request # 5 - Receiving Intraday data for 6E.20140600.CME_Fo starting at 2014-03-16 23:00:00 | 2014-07-04 08:46:46 HD Request # 5 - Truncating Intraday data file at 2014-03-16 23:00:00 while receiving initial tick data during multistage download. | 2014-07-04 08:46:46 HD Request # 5 - Timestamp of first Intraday data file record written: 2014-03-16 23:00:00 | 2014-07-04 08:46:46 Date rule based rollover from 6E.20131200.CME_Fo to next contract occurs at 2013-12-16. | 2014-07-04 08:47:11 Date rule based rollover from 6E.20140300.CME_Fo to next contract occurs at 2014-03-17. | 2014-07-04 08:47:11 Date rule based rollover from 6E.20140600.CME_Fo to next contract occurs at 2014-06-16. | 2014-07-04 08:47:11 Date rule based rollover from 6E.20140900.CME_Fo to next contract occurs at 2014-09-15. | 2014-07-04 08:47:11 Checking Intraday data file for symbol 6E.20131200.CME_Fo for the date range from 2013-09-16 to 2013-12-16. | 2014-07-04 08:47:11 Checking Daily data file for symbol E6Z13 for the date range from 2013-09-16 to 2013-12-16. | 2014-07-04 08:47:11 Checking Intraday data file for symbol 6E.20140300.CME_Fo for the date range from 2013-12-16 to 2014-03-17. | 2014-07-04 08:47:11 Checking Daily data file for symbol E6H14 for the date range from 2013-12-16 to 2014-03-17. | 2014-07-04 08:47:11 Checking Intraday data file for symbol 6E.20140600.CME_Fo for the date range from 2014-03-17 to 2014-06-16. | 2014-07-04 08:47:11 Not downloading historical Intraday data for 6E.20140600.CME_Fo because data is currently being downloaded for this symbol. | 2014-07-04 08:47:11 Checking Daily data file for symbol E6M14 for the date range from 2014-03-17 to 2014-06-16. | 2014-07-04 08:47:11 Intraday data file for 6E.20140900.CME_Fo exists and is empty. Skipping Intraday data download. | 2014-07-04 08:47:11 Checking Daily data file for symbol E6U14 for the date range from 2014-06-16 to 0. | 2014-07-04 08:47:11 Symbols used for 6E.20140900.CME_Fo continuous contract chart: | 2014-07-04 08:47:11 6E.20131200.CME_Fo | 2014-07-04 08:47:11 6E.20140300.CME_Fo | 2014-07-04 08:47:11 6E.20140600.CME_Fo | 2014-07-04 08:47:11 6E.20140900.CME_Fo | 2014-07-04 08:47:11 Socket (3040) - Shutdown and closed. | 2014-07-04 08:48:07 The network socket for historical data has been closed. | 2014-07-04 08:48:07 HD Request # 5 - Received 5094331 records from 2014-03-16 23:00:00 to 2014-06-16 16:06:37 (91.7 days) and wrote 5094331 records for 6E.20140600.CME_Fo | 2014-07-04 08:48:07 HD Request # 5 - Intraday download COMPLETE for 6E.20140600.CME_Fo. Completion time: 1m 22s | 2014-07-04 08:48:07 Real-time Intraday chart data file updates started for 6E.20140600.CME_Fo | 2014-07-04 08:48:07 HD Request # 5 - Enabling Intraday chart updating for symbol. | 2014-07-04 08:48:07 HD Request # 5 - Reloading Intraday charts for symbol. | 2014-07-04 08:48:07 Reloading all charts with filename: 6E.20140600.CME_Fo.scid | 2014-07-04 08:48:07 HD Request # 6 - Downloading Intraday chart data for 6E.20131200.CME_Fo to the file 6E.20131200.CME_Fo.scid. Service: cme | 2014-07-04 08:48:07 Compressing file: C:\SierraChart\Data\6E.20131200.CME_Fo.scid. This may take a while... | 2014-07-04 08:48:07 HD Request # 6 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:48:07 HD Request # 6 - Download start Date-Time: 2013-09-14 02:00:00.0 | 2014-07-04 08:48:07 HD Request # 6 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:48:07 HD Request # 6 - Using server: scdf1.sierracharts.com port 10149 | 2014-07-04 08:48:07 Socket (0) - Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2014-07-04 08:48:07 Socket (3040) - Connected. | 2014-07-04 08:48:08 HD Request # 6 - Sending historical data logon request message. | 2014-07-04 08:48:08 6E.20140900.CME_Fo [CBV] 0.0004 Range #5: Download is complete for all contract months in chart. Proceeding with data load. | 2014-07-04 08:48:08 Volume based rollover from 6E.20140600.CME_Fo to 6E.20140900.CME_Fo occurs at 2014-06-13 | 2014-07-04 08:48:08 6E.20140900.CME_Fo [CBV] 0.0004 Range #5: Performing continuous futures contract back adjustment calculations. | 2014-07-04 08:48:08 6E.20140900.CME_Fo [CBV] 0.0004 Range #5: 6E.20140600.CME_Fo Open price on 2014-06-13 is 1.3551. | 2014-07-04 08:48:08 6E.20140900.CME_Fo [CBV] 0.0004 Range #5: 6E.20140900.CME_Fo Open price on 2014-06-13 is 1.3555. | 2014-07-04 08:48:08 6E.20140900.CME_Fo [CBV] 0.0004 Range #5: 6E.20140600.CME_Fo price difference to 6E.20140900.CME_Fo is 0.00040000. | 2014-07-04 08:48:08 6E.20140900.CME_Fo [CBV] 0.0004 Range #5: Back adjust amount for symbol 6E.20140600.CME_Fo is 4. | 2014-07-04 08:48:08 Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\6E.20140900.CME_Fo.scid | 2014-07-04 08:48:08 HD Request # 6 - Requesting Intraday data. Start Date-Time: 2013-09-14 02:00:00. Record interval: 60. Symbol: 6EZ3 | 2014-07-04 08:48:08 HD Request # 6 - Decompressing data. | 2014-07-04 08:48:08 CTS T4 FIX - Starting real-time market data updates for: 6E.20140900.CME_Fo. ID: 5 | 2014-07-04 08:48:08 HD Request # 7 - Downloading Intraday chart data for 6E.20140900.CME_Fo to the file 6E.20140900.CME_Fo.scid. Service: cts | 2014-07-04 08:48:08 Compressing file: C:\SierraChart\Data\6E.20140900.CME_Fo.scid. This may take a while... | 2014-07-04 08:48:08 HD Request # 7 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:48:08 HD Request # 7 - Download start Date-Time: 2013-12-30 07:48:08.0 | 2014-07-04 08:48:08 HD Request # 7 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:48:08 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-07-04 08:48:08 HD Request # 6 - Receiving Intraday data for 6E.20131200.CME_Fo starting at 2013-09-16 00:00:00 | 2014-07-04 08:48:08 HD Request # 6 - Timestamp of first Intraday data file record written: 2013-09-16 00:00:00 | 2014-07-04 08:48:08 CTS FIX Historical Data socket (0) - Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-07-04 08:48:09 CTS FIX Historical Data socket (2288) - Connected. | 2014-07-04 08:48:10 CTS FIX Historical Data socket (2288) - Starting SSL connection. | 2014-07-04 08:48:10 CTS T4 FIX: Sending security definition request for symbol 6E.20140900.CME_Fo | 2014-07-04 08:48:10 CTS T4 FIX: Received matching security definition for symbol 6E.20140900.CME_Fo. Subscribing to data. | 2014-07-04 08:48:11 CTS T4 FIX: Received 1 security definitions for underlying symbol 6E | 2014-07-04 08:48:11 CTS FIX Historical Data socket (2288) - SSL connection established. | 2014-07-04 08:48:11 CTS FIX: Received a Reject <3> message. Reference Sequence Num = 11. RefTagID = 265. Reference Message Type = V. SessionRejectReason = 5. Text = Value is incorrect (out of range) for this tag | 2014-07-04 08:48:11 CTS FIX: Received a Logout message. Text = MDUpdateType Tag (265) is out range - Please use range 0 to 10 | 2014-07-04 08:48:11 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-07-04 08:48:11 CTS FIX socket (1268) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:48:11 CTS FIX socket (1268) - SSL has been shut down. | 2014-07-04 08:48:11 CTS FIX socket (1268) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:11 CTS FIX socket (1268) - Shutdown and closed. | 2014-07-04 08:48:11 CTS FIX: Logged out and disconnected. | 2014-07-04 08:48:11 Connection to the external service has been lost. | 2014-07-04 08:48:11 HD Request # 7 - Download canceled. | 2014-07-04 08:48:11 HD Request # 7 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E.20140900.CME_Fo | 2014-07-04 08:48:11 HD Request # 7 - Intraday download COMPLETE for 6E.20140900.CME_Fo. Completion time: 3s | 2014-07-04 08:48:11 Canceling download request for 6E.20140900.CME_Fo Intraday data. | 2014-07-04 08:48:11 CTS FIX Historical Data socket (2288) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:48:11 CTS FIX Historical Data socket (2288) - SSL has been shut down. | 2014-07-04 08:48:11 CTS FIX Historical Data socket (2288) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:11 CTS FIX Historical Data socket (2288) - Shutdown and closed. | 2014-07-04 08:48:11 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:11 CTS FIX Historical Data: Disconnected. | 2014-07-04 08:48:11 CTS FIX: Disconnected. | 2014-07-04 08:48:11 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:48:11 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-07-04 08:48:14 CTS FIX - Firm: Dorman | 2014-07-04 08:48:14 CTS FIX socket (0) - Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-07-04 08:48:15 CTS FIX socket (2288) - Connected. | 2014-07-04 08:48:16 CTS FIX socket (2288) - Starting SSL connection. | 2014-07-04 08:48:16 CTS FIX socket (2288) - SSL connection established. | 2014-07-04 08:48:18 CTS FIX: Sending the Logon message. | 2014-07-04 08:48:18 Socket (3040) - Shutdown and closed. | 2014-07-04 08:48:19 The network socket for historical data has been closed. | 2014-07-04 08:48:19 HD Request # 6 - Received 84135 records from 2013-09-16 00:00:00 to 2013-12-16 16:12:49 (91.7 days) and wrote 84135 records for 6E.20131200.CME_Fo | 2014-07-04 08:48:19 HD Request # 6 - Intraday download COMPLETE for 6E.20131200.CME_Fo. Completion time: 12s | 2014-07-04 08:48:19 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-07-04 08:48:19 HD Request # 8 - Downloading Intraday chart data for 6E.20131200.CME_Fo to the file 6E.20131200.CME_Fo.scid. Service: cme | 2014-07-04 08:48:19 HD Request # 8 - Download start Date-Time: 2013-09-14 02:00:00.0 | 2014-07-04 08:48:19 HD Request # 8 - Using server: scdf2.sierracharts.com port 10149 | 2014-07-04 08:48:19 Socket (0) - Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2014-07-04 08:48:19 CTS T4 FIX - Starting real-time market data updates for: @EUU14. ID: 2 | 2014-07-04 08:48:19 Symbol Error - @EUU14 is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:19 Socket (2208) - Connected. | 2014-07-04 08:48:19 HD Request # 8 - Sending historical data logon request message. | 2014-07-04 08:48:19 HD Request # 8 - Requesting Intraday data. Start Date-Time: 2013-09-14 02:00:00. Record interval: 0. Symbol: 6EZ3 | 2014-07-04 08:48:20 CTS FIX: Received Account List collateral report. | 2014-07-04 08:48:20 CTS FIX: Subscribing to account: DT* | 2014-07-04 08:48:20 HD Request # 8 - Decompressing data. | 2014-07-04 08:48:20 HD Request # 8 - Receiving Intraday data for 6E.20131200.CME_Fo starting at 2013-09-16 00:00:00 | 2014-07-04 08:48:20 HD Request # 8 - Truncating Intraday data file at 2013-09-16 00:00:00 while receiving initial tick data during multistage download. | 2014-07-04 08:48:20 HD Request # 8 - Timestamp of first Intraday data file record written: 2013-09-16 00:00:00 | 2014-07-04 08:48:20 HD Request # 9 - Downloading Intraday chart data for @EUU14 to the file @EUU14.scid. Service: cts | 2014-07-04 08:48:20 HD Request # 9 - Download start Date-Time: 2014-07-03 18:49:20.0 | 2014-07-04 08:48:20 HD Request # 9 - Error downloading historical Intraday data for @EUU14. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:20 HD Request # 9 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @EUU14 | 2014-07-04 08:48:21 HD Request # 9 - Intraday download COMPLETE for @EUU14. Completion time: 0s | 2014-07-04 08:48:21 Real-time Intraday chart data file updates started for @EUU14 | 2014-07-04 08:48:21 HD Request # 9 - Enabling Intraday chart updating for symbol. | 2014-07-04 08:48:21 CTS T4 FIX - Starting real-time market data updates for: 6E.20140900.CME_Fo. ID: 3 | 2014-07-04 08:48:21 HD Request # 10 - Downloading Intraday chart data for 6E.20140900.CME_Fo to the file 6E.20140900.CME_Fo.scid. Service: cts | 2014-07-04 08:48:21 HD Request # 10 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:48:21 HD Request # 10 - Download start Date-Time: 2013-12-30 07:48:21.0 | 2014-07-04 08:48:21 HD Request # 10 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:48:21 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-07-04 08:48:21 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:48:21 CTS T4 FIX - Starting real-time market data updates for: TICK.Z. ID: 4 | 2014-07-04 08:48:21 Symbol Error - TICK.Z is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:21 Chart #4 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:48:21 CTS T4 FIX: Sending security definition request for symbol 6E.20140900.CME_Fo | 2014-07-04 08:48:21 CTS FIX Historical Data socket (0) - Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-07-04 08:48:21 CTS T4 FIX: Received matching security definition for symbol 6E.20140900.CME_Fo. Subscribing to data. | 2014-07-04 08:48:21 CTS T4 FIX: Received 1 security definitions for underlying symbol 6E | 2014-07-04 08:48:21 CTS FIX Historical Data socket (2260) - Connected. | 2014-07-04 08:48:21 CTS FIX Historical Data socket (2260) - Starting SSL connection. | 2014-07-04 08:48:21 CTS FIX socket (2288) - Closed. No error. | 2014-07-04 08:48:21 CTS FIX socket (2288) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:48:21 CTS FIX socket (2288) - SSL has been shut down. | 2014-07-04 08:48:21 CTS FIX socket (2288) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:21 CTS FIX socket (2288) - Shutdown and closed. | 2014-07-04 08:48:21 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:21 Connection to the external service has been lost. | 2014-07-04 08:48:21 HD Request # 10 - Download canceled. | 2014-07-04 08:48:22 HD Request # 10 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E.20140900.CME_Fo | 2014-07-04 08:48:22 HD Request # 10 - Intraday download COMPLETE for 6E.20140900.CME_Fo. Completion time: 1s | 2014-07-04 08:48:22 Canceling download request for 6E.20140900.CME_Fo Intraday data. | 2014-07-04 08:48:22 CTS FIX Historical Data socket (2260) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:22 CTS FIX Historical Data socket (2260) - Shutdown and closed. | 2014-07-04 08:48:22 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:22 CTS FIX Historical Data: Disconnected. | 2014-07-04 08:48:22 CTS FIX: Disconnected. | 2014-07-04 08:48:22 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:48:22 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-07-04 08:48:25 CTS FIX - Firm: Dorman | 2014-07-04 08:48:25 CTS FIX socket (0) - Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-07-04 08:48:25 CTS FIX socket (2260) - Connected. | 2014-07-04 08:48:25 CTS FIX socket (2260) - Starting SSL connection. | 2014-07-04 08:48:25 CTS FIX socket (2260) - SSL connection established. | 2014-07-04 08:48:25 CTS FIX: Sending the Logon message. | 2014-07-04 08:48:25 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-07-04 08:48:26 CTS T4 FIX - Starting real-time market data updates for: @EUU14. ID: 1 | 2014-07-04 08:48:26 Symbol Error - @EUU14 is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:26 CTS FIX: Received Account List collateral report. | 2014-07-04 08:48:27 CTS FIX: Subscribing to account: DT* | 2014-07-04 08:48:27 HD Request # 11 - Downloading Intraday chart data for @EUU14 to the file @EUU14.scid. Service: cts | 2014-07-04 08:48:27 HD Request # 11 - Download start Date-Time: 2014-07-03 18:49:20.0 | 2014-07-04 08:48:27 HD Request # 11 - Error downloading historical Intraday data for @EUU14. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:27 HD Request # 11 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @EUU14 | 2014-07-04 08:48:27 HD Request # 11 - Intraday download COMPLETE for @EUU14. Completion time: 0s | 2014-07-04 08:48:27 Real-time Intraday chart data file updates started for @EUU14 | 2014-07-04 08:48:27 HD Request # 11 - Enabling Intraday chart updating for symbol. | 2014-07-04 08:48:27 CTS T4 FIX - Starting real-time market data updates for: 6E.20140900.CME_Fo. ID: 2 | 2014-07-04 08:48:27 HD Request # 12 - Downloading Intraday chart data for 6E.20140900.CME_Fo to the file 6E.20140900.CME_Fo.scid. Service: cts | 2014-07-04 08:48:27 HD Request # 12 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:48:27 HD Request # 12 - Download start Date-Time: 2013-12-30 07:48:27.0 | 2014-07-04 08:48:27 HD Request # 12 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:48:27 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-07-04 08:48:27 CTS FIX Historical Data socket (0) - Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-07-04 08:48:27 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:48:27 CTS T4 FIX - Starting real-time market data updates for: TICK.Z. ID: 3 | 2014-07-04 08:48:27 Symbol Error - TICK.Z is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:27 CTS T4 FIX: Sending security definition request for symbol 6E.20140900.CME_Fo | 2014-07-04 08:48:27 Chart #4 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:48:27 CTS FIX Historical Data socket (3068) - Connected. | 2014-07-04 08:48:28 CTS FIX Historical Data socket (3068) - Starting SSL connection. | 2014-07-04 08:48:28 CTS T4 FIX: Received matching security definition for symbol 6E.20140900.CME_Fo. Subscribing to data. | 2014-07-04 08:48:28 CTS T4 FIX: Received 1 security definitions for underlying symbol 6E | 2014-07-04 08:48:28 CTS FIX socket (2260) - Closed. No error. | 2014-07-04 08:48:28 CTS FIX socket (2260) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:48:28 CTS FIX socket (2260) - SSL has been shut down. | 2014-07-04 08:48:28 CTS FIX socket (2260) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:28 CTS FIX socket (2260) - Shutdown and closed. | 2014-07-04 08:48:28 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:28 Connection to the external service has been lost. | 2014-07-04 08:48:28 HD Request # 12 - Download canceled. | 2014-07-04 08:48:28 HD Request # 12 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E.20140900.CME_Fo | 2014-07-04 08:48:28 HD Request # 12 - Intraday download COMPLETE for 6E.20140900.CME_Fo. Completion time: 1s | 2014-07-04 08:48:28 Canceling download request for 6E.20140900.CME_Fo Intraday data. | 2014-07-04 08:48:28 CTS FIX Historical Data socket (3068) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:28 CTS FIX Historical Data socket (3068) - Shutdown and closed. | 2014-07-04 08:48:28 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:28 CTS FIX Historical Data: Disconnected. | 2014-07-04 08:48:28 CTS FIX: Disconnected. | 2014-07-04 08:48:28 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:48:28 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-07-04 08:48:31 CTS FIX - Firm: Dorman | 2014-07-04 08:48:31 CTS FIX socket (0) - Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-07-04 08:48:31 CTS FIX socket (3104) - Connected. | 2014-07-04 08:48:33 CTS FIX socket (3104) - Starting SSL connection. | 2014-07-04 08:48:33 CTS FIX socket (3104) - SSL connection established. | 2014-07-04 08:48:35 CTS FIX: Sending the Logon message. | 2014-07-04 08:48:35 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-07-04 08:48:36 CTS T4 FIX - Starting real-time market data updates for: @EUU14. ID: 1 | 2014-07-04 08:48:36 Symbol Error - @EUU14 is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:36 CTS FIX: Received Account List collateral report. | 2014-07-04 08:48:37 CTS FIX: Subscribing to account: DT* | 2014-07-04 08:48:37 HD Request # 13 - Downloading Intraday chart data for @EUU14 to the file @EUU14.scid. Service: cts | 2014-07-04 08:48:37 HD Request # 13 - Download start Date-Time: 2014-07-03 18:49:20.0 | 2014-07-04 08:48:37 HD Request # 13 - Error downloading historical Intraday data for @EUU14. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:37 HD Request # 13 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @EUU14 | 2014-07-04 08:48:38 HD Request # 13 - Intraday download COMPLETE for @EUU14. Completion time: 1s | 2014-07-04 08:48:38 Real-time Intraday chart data file updates started for @EUU14 | 2014-07-04 08:48:38 HD Request # 13 - Enabling Intraday chart updating for symbol. | 2014-07-04 08:48:38 CTS T4 FIX - Starting real-time market data updates for: 6E.20140900.CME_Fo. ID: 2 | 2014-07-04 08:48:38 HD Request # 14 - Downloading Intraday chart data for 6E.20140900.CME_Fo to the file 6E.20140900.CME_Fo.scid. Service: cts | 2014-07-04 08:48:38 HD Request # 14 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:48:38 HD Request # 14 - Download start Date-Time: 2013-12-30 07:48:38.0 | 2014-07-04 08:48:38 HD Request # 14 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:48:38 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-07-04 08:48:38 Chart #6 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:48:38 CTS T4 FIX - Starting real-time market data updates for: TICK.Z. ID: 3 | 2014-07-04 08:48:38 Symbol Error - TICK.Z is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:38 Chart #4 has tagged chart #5 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:48:38 CTS T4 FIX: Sending security definition request for symbol 6E.20140900.CME_Fo | 2014-07-04 08:48:38 CTS FIX Historical Data socket (0) - Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-07-04 08:48:38 CTS T4 FIX: Received matching security definition for symbol 6E.20140900.CME_Fo. Subscribing to data. | 2014-07-04 08:48:39 CTS T4 FIX: Received 1 security definitions for underlying symbol 6E | 2014-07-04 08:48:39 CTS FIX: Received Account Update collateral report. | 2014-07-04 08:48:39 CTS FIX Historical Data socket (3184) - Connected. | 2014-07-04 08:48:39 CTS FIX Historical Data socket (3184) - Starting SSL connection. | 2014-07-04 08:48:39 CTS FIX: Received a Reject <3> message. Reference Sequence Num = 5. RefTagID = 265. Reference Message Type = V. SessionRejectReason = 5. Text = Value is incorrect (out of range) for this tag | 2014-07-04 08:48:39 CTS FIX: Received a Logout message. Text = MDUpdateType Tag (265) is out range - Please use range 0 to 10 | 2014-07-04 08:48:39 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-07-04 08:48:39 CTS FIX socket (3104) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:48:39 CTS FIX socket (3104) - SSL has been shut down. | 2014-07-04 08:48:39 CTS FIX socket (3104) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:39 CTS FIX socket (3104) - Shutdown and closed. | 2014-07-04 08:48:39 CTS FIX: Logged out and disconnected. | 2014-07-04 08:48:39 Connection to the external service has been lost. | 2014-07-04 08:48:39 HD Request # 14 - Download canceled. | 2014-07-04 08:48:39 HD Request # 14 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E.20140900.CME_Fo | 2014-07-04 08:48:39 HD Request # 14 - Intraday download COMPLETE for 6E.20140900.CME_Fo. Completion time: 1s | 2014-07-04 08:48:39 Canceling download request for 6E.20140900.CME_Fo Intraday data. | 2014-07-04 08:48:39 CTS FIX Historical Data socket (3184) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:39 CTS FIX Historical Data socket (3184) - Shutdown and closed. | 2014-07-04 08:48:39 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:39 CTS FIX Historical Data: Disconnected. | 2014-07-04 08:48:39 CTS FIX: Disconnected. | 2014-07-04 08:48:39 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:48:39 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-07-04 08:48:42 CTS FIX - Firm: Dorman | 2014-07-04 08:48:42 CTS FIX socket (0) - Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-07-04 08:48:43 CTS FIX socket (3080) - Connected. | 2014-07-04 08:48:43 CTS FIX socket (3080) - Starting SSL connection. | 2014-07-04 08:48:43 CTS FIX socket (3080) - SSL connection established. | 2014-07-04 08:48:44 CTS FIX: Sending the Logon message. | 2014-07-04 08:48:45 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-07-04 08:48:45 CTS T4 FIX - Starting real-time market data updates for: @EUU14. ID: 1 | 2014-07-04 08:48:45 Symbol Error - @EUU14 is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:45 CTS FIX: Received Account List collateral report. | 2014-07-04 08:48:46 CTS FIX: Subscribing to account: DT* | 2014-07-04 08:48:46 HD Request # 15 - Downloading Intraday chart data for @EUU14 to the file @EUU14.scid. Service: cts | 2014-07-04 08:48:46 HD Request # 15 - Download start Date-Time: 2014-07-03 18:49:20.0 | 2014-07-04 08:48:46 HD Request # 15 - Error downloading historical Intraday data for @EUU14. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:46 HD Request # 15 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @EUU14 | 2014-07-04 08:48:46 HD Request # 15 - Intraday download COMPLETE for @EUU14. Completion time: 0s | 2014-07-04 08:48:46 Real-time Intraday chart data file updates started for @EUU14 | 2014-07-04 08:48:46 HD Request # 15 - Enabling Intraday chart updating for symbol. | 2014-07-04 08:48:46 CTS T4 FIX - Starting real-time market data updates for: TICK.Z. ID: 2 | 2014-07-04 08:48:46 Symbol Error - TICK.Z is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:46 HD Request # 16 - Downloading Intraday chart data for TICK.Z to the file TICK.Z.scid. Service: cts | 2014-07-04 08:48:46 HD Request # 16 - Download start Date-Time: 2014-07-03 18:49:32.0 | 2014-07-04 08:48:46 HD Request # 16 - Error downloading historical Intraday data for TICK.Z. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:46 HD Request # 16 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK.Z | 2014-07-04 08:48:46 HD Request # 16 - Intraday download COMPLETE for TICK.Z. Completion time: 0s | 2014-07-04 08:48:46 Real-time Intraday chart data file updates started for TICK.Z | 2014-07-04 08:48:46 CTS T4 FIX - Starting real-time market data updates for: 6E.20140900.CME_Fo. ID: 3 | 2014-07-04 08:48:47 HD Request # 17 - Downloading Intraday chart data for 6E.20140900.CME_Fo to the file 6E.20140900.CME_Fo.scid. Service: cts | 2014-07-04 08:48:47 HD Request # 17 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:48:47 HD Request # 17 - Download start Date-Time: 2013-12-30 07:48:47.0 | 2014-07-04 08:48:47 HD Request # 17 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:48:47 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-07-04 08:48:47 CTS FIX Historical Data socket (0) - Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-07-04 08:48:47 Chart #2 has tagged chart #6 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:48:47 CTS T4 FIX: Sending security definition request for symbol 6E.20140900.CME_Fo | 2014-07-04 08:48:47 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: Monsetup.cht | 2014-07-04 08:48:47 CTS FIX Historical Data socket (3200) - Connected. | 2014-07-04 08:48:47 CTS FIX Historical Data socket (3200) - Starting SSL connection. | 2014-07-04 08:48:47 CTS T4 FIX: Received matching security definition for symbol 6E.20140900.CME_Fo. Subscribing to data. | 2014-07-04 08:48:48 CTS T4 FIX: Received 1 security definitions for underlying symbol 6E | 2014-07-04 08:48:48 CTS FIX socket (3080) - Closed. No error. | 2014-07-04 08:48:48 CTS FIX socket (3080) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:48:48 CTS FIX socket (3080) - SSL has been shut down. | 2014-07-04 08:48:48 CTS FIX socket (3080) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:48 CTS FIX socket (3080) - Shutdown and closed. | 2014-07-04 08:48:48 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:48 Connection to the external service has been lost. | 2014-07-04 08:48:48 HD Request # 17 - Download canceled. | 2014-07-04 08:48:48 HD Request # 17 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E.20140900.CME_Fo | 2014-07-04 08:48:48 HD Request # 17 - Intraday download COMPLETE for 6E.20140900.CME_Fo. Completion time: 0s | 2014-07-04 08:48:48 Canceling download request for 6E.20140900.CME_Fo Intraday data. | 2014-07-04 08:48:48 CTS FIX Historical Data socket (3200) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:48 CTS FIX Historical Data socket (3200) - Shutdown and closed. | 2014-07-04 08:48:48 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:48 CTS FIX Historical Data: Disconnected. | 2014-07-04 08:48:48 CTS FIX: Disconnected. | 2014-07-04 08:48:48 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:48:48 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-07-04 08:48:51 CTS FIX - Firm: Dorman | 2014-07-04 08:48:51 CTS FIX socket (0) - Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-07-04 08:48:51 CTS FIX socket (3232) - Connected. | 2014-07-04 08:48:52 CTS FIX socket (3232) - Starting SSL connection. | 2014-07-04 08:48:52 CTS FIX socket (3232) - SSL connection established. | 2014-07-04 08:48:53 CTS FIX: Sending the Logon message. | 2014-07-04 08:48:53 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-07-04 08:48:54 CTS T4 FIX - Starting real-time market data updates for: @EUU14. ID: 1 | 2014-07-04 08:48:54 Symbol Error - @EUU14 is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:54 HD Request # 18 - Downloading Intraday chart data for @EUU14 to the file @EUU14.scid. Service: cts | 2014-07-04 08:48:55 HD Request # 18 - Download start Date-Time: 2014-07-03 18:49:20.0 | 2014-07-04 08:48:55 HD Request # 18 - Error downloading historical Intraday data for @EUU14. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:55 HD Request # 18 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @EUU14 | 2014-07-04 08:48:55 HD Request # 18 - Intraday download COMPLETE for @EUU14. Completion time: 0s | 2014-07-04 08:48:55 Real-time Intraday chart data file updates started for @EUU14 | 2014-07-04 08:48:55 HD Request # 18 - Enabling Intraday chart updating for symbol. | 2014-07-04 08:48:55 CTS FIX: Received Account List collateral report. | 2014-07-04 08:48:55 CTS FIX: Subscribing to account: DT* | 2014-07-04 08:48:55 CTS T4 FIX - Starting real-time market data updates for: 6E.20140900.CME_Fo. ID: 2 | 2014-07-04 08:48:55 HD Request # 19 - Downloading Intraday chart data for 6E.20140900.CME_Fo to the file 6E.20140900.CME_Fo.scid. Service: cts | 2014-07-04 08:48:55 HD Request # 19 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:48:55 HD Request # 19 - Download start Date-Time: 2013-12-30 07:48:55.0 | 2014-07-04 08:48:55 HD Request # 19 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:48:55 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-07-04 08:48:55 CTS T4 FIX - Starting real-time market data updates for: TICK.Z. ID: 3 | 2014-07-04 08:48:55 Symbol Error - TICK.Z is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:48:55 CTS T4 FIX: Sending security definition request for symbol 6E.20140900.CME_Fo | 2014-07-04 08:48:55 CTS T4 FIX: Received matching security definition for symbol 6E.20140900.CME_Fo. Subscribing to data. | 2014-07-04 08:48:56 CTS T4 FIX: Received 1 security definitions for underlying symbol 6E | 2014-07-04 08:48:56 CTS FIX Historical Data socket (0) - Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-07-04 08:48:56 CTS FIX Historical Data socket (3080) - Connected. | 2014-07-04 08:48:56 CTS FIX Historical Data socket (3080) - Starting SSL connection. | 2014-07-04 08:48:56 CTS FIX socket (3232) - Closed. No error. | 2014-07-04 08:48:57 CTS FIX socket (3232) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:48:57 CTS FIX socket (3232) - SSL has been shut down. | 2014-07-04 08:48:57 CTS FIX socket (3232) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:57 CTS FIX socket (3232) - Shutdown and closed. | 2014-07-04 08:48:57 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:57 Connection to the external service has been lost. | 2014-07-04 08:48:57 HD Request # 19 - Download canceled. | 2014-07-04 08:48:57 HD Request # 19 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E.20140900.CME_Fo | 2014-07-04 08:48:57 HD Request # 19 - Intraday download COMPLETE for 6E.20140900.CME_Fo. Completion time: 2s | 2014-07-04 08:48:57 Canceling download request for 6E.20140900.CME_Fo Intraday data. | 2014-07-04 08:48:57 CTS FIX Historical Data socket (3080) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:48:57 CTS FIX Historical Data socket (3080) - Shutdown and closed. | 2014-07-04 08:48:57 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:48:57 CTS FIX Historical Data: Disconnected. | 2014-07-04 08:48:57 CTS FIX: Disconnected. | 2014-07-04 08:48:57 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:48:57 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-07-04 08:49:00 CTS FIX - Firm: Dorman | 2014-07-04 08:49:00 CTS FIX socket (0) - Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-07-04 08:49:00 CTS FIX socket (3080) - Connected. | 2014-07-04 08:49:01 CTS FIX socket (3080) - Starting SSL connection. | 2014-07-04 08:49:01 CTS FIX socket (3080) - SSL connection established. | 2014-07-04 08:49:02 CTS FIX: Sending the Logon message. | 2014-07-04 08:49:02 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-07-04 08:49:02 CTS T4 FIX - Starting real-time market data updates for: @EUU14. ID: 1 | 2014-07-04 08:49:02 Symbol Error - @EUU14 is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:49:02 CTS FIX: Received Account List collateral report. | 2014-07-04 08:49:03 CTS FIX: Subscribing to account: DT* | 2014-07-04 08:49:03 HD Request # 20 - Downloading Intraday chart data for @EUU14 to the file @EUU14.scid. Service: cts | 2014-07-04 08:49:03 HD Request # 20 - Download start Date-Time: 2014-07-03 18:49:20.0 | 2014-07-04 08:49:03 HD Request # 20 - Error downloading historical Intraday data for @EUU14. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:49:03 HD Request # 20 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @EUU14 | 2014-07-04 08:49:04 HD Request # 20 - Intraday download COMPLETE for @EUU14. Completion time: 0s | 2014-07-04 08:49:04 Real-time Intraday chart data file updates started for @EUU14 | 2014-07-04 08:49:04 HD Request # 20 - Enabling Intraday chart updating for symbol. | 2014-07-04 08:49:04 CTS FIX: Received Account Update collateral report. | 2014-07-04 08:49:04 CTS T4 FIX - Starting real-time market data updates for: 6E.20140900.CME_Fo. ID: 2 | 2014-07-04 08:49:04 HD Request # 21 - Downloading Intraday chart data for 6E.20140900.CME_Fo to the file 6E.20140900.CME_Fo.scid. Service: cts | 2014-07-04 08:49:04 HD Request # 21 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:49:04 HD Request # 21 - Download start Date-Time: 2013-12-30 07:49:04.0 | 2014-07-04 08:49:04 HD Request # 21 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:49:04 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-07-04 08:49:04 CTS FIX Historical Data socket (0) - Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-07-04 08:49:04 CTS T4 FIX - Starting real-time market data updates for: TICK.Z. ID: 3 | 2014-07-04 08:49:04 Symbol Error - TICK.Z is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:49:04 CTS T4 FIX: Sending security definition request for symbol 6E.20140900.CME_Fo | 2014-07-04 08:49:04 CTS FIX Historical Data socket (3340) - Connected. | 2014-07-04 08:49:04 CTS FIX Historical Data socket (3340) - Starting SSL connection. | 2014-07-04 08:49:04 CTS T4 FIX: Received matching security definition for symbol 6E.20140900.CME_Fo. Subscribing to data. | 2014-07-04 08:49:04 CTS T4 FIX: Received 1 security definitions for underlying symbol 6E | 2014-07-04 08:49:04 CTS FIX: Received a Reject <3> message. Reference Sequence Num = 5. RefTagID = 265. Reference Message Type = V. SessionRejectReason = 5. Text = Value is incorrect (out of range) for this tag | 2014-07-04 08:49:05 CTS FIX socket (3080) - Closed. No error. | 2014-07-04 08:49:05 CTS FIX socket (3080) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:49:05 CTS FIX socket (3080) - SSL has been shut down. | 2014-07-04 08:49:05 CTS FIX socket (3080) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:49:05 CTS FIX socket (3080) - Shutdown and closed. | 2014-07-04 08:49:05 CTS FIX: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:49:05 Connection to the external service has been lost. | 2014-07-04 08:49:05 HD Request # 21 - Download canceled. | 2014-07-04 08:49:05 HD Request # 21 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E.20140900.CME_Fo | 2014-07-04 08:49:05 HD Request # 21 - Intraday download COMPLETE for 6E.20140900.CME_Fo. Completion time: 1s | 2014-07-04 08:49:05 Canceling download request for 6E.20140900.CME_Fo Intraday data. | 2014-07-04 08:49:05 CTS FIX Historical Data socket (3340) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:49:05 CTS FIX Historical Data socket (3340) - Shutdown and closed. | 2014-07-04 08:49:05 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:49:05 CTS FIX Historical Data: Disconnected. | 2014-07-04 08:49:05 CTS FIX: Disconnected. | 2014-07-04 08:49:05 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:49:05 CTS FIX - Connecting to CTS Simulation server fix-sim.t4login.com:10443 | 2014-07-04 08:49:08 CTS FIX - Firm: Dorman | 2014-07-04 08:49:08 CTS FIX socket (0) - Resolved address fix-sim.t4login.com to IP 74.201.6.199 | 2014-07-04 08:49:08 CTS FIX socket (3372) - Connected. | 2014-07-04 08:49:08 CTS FIX socket (3372) - Starting SSL connection. | 2014-07-04 08:49:08 CTS FIX socket (3372) - SSL connection established. | 2014-07-04 08:49:09 CTS FIX: Sending the Logon message. | 2014-07-04 08:49:10 CTS FIX: Connected to data and trade server. FIX version: 4.3.7.0 | 2014-07-04 08:49:10 CTS T4 FIX - Starting real-time market data updates for: TICK.Z. ID: 1 | 2014-07-04 08:49:10 Symbol Error - TICK.Z is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:49:10 HD Request # 22 - Downloading Intraday chart data for TICK.Z to the file TICK.Z.scid. Service: cts | 2014-07-04 08:49:10 HD Request # 22 - Download start Date-Time: 2014-07-03 18:49:32.0 | 2014-07-04 08:49:10 HD Request # 22 - Error downloading historical Intraday data for TICK.Z. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:49:10 HD Request # 22 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for TICK.Z | 2014-07-04 08:49:10 HD Request # 22 - Intraday download COMPLETE for TICK.Z. Completion time: 0s | 2014-07-04 08:49:10 Real-time Intraday chart data file updates started for TICK.Z | 2014-07-04 08:49:10 HD Request # 22 - Enabling Intraday chart updating for symbol. | 2014-07-04 08:49:10 CTS T4 FIX - Starting real-time market data updates for: @EUU14. ID: 2 | 2014-07-04 08:49:10 Symbol Error - @EUU14 is unknown, unavailable, or improperly formatted. CTS T4 FIX: Symbol format needs to be [contract].[market].[exchange]. | 2014-07-04 08:49:10 CTS FIX: Received Account List collateral report. | 2014-07-04 08:49:11 CTS FIX: Subscribing to account: DT* | 2014-07-04 08:49:11 HD Request # 23 - Downloading Intraday chart data for @EUU14 to the file @EUU14.scid. Service: cts | 2014-07-04 08:49:11 HD Request # 23 - Download start Date-Time: 2014-07-03 18:49:20.0 | 2014-07-04 08:49:11 HD Request # 23 - Error downloading historical Intraday data for @EUU14. CTS FIX Historical Data. Invalid symbol format. Needs to be [contract].[market].[exchange]. | 2014-07-04 08:49:11 HD Request # 23 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for @EUU14 | 2014-07-04 08:49:12 HD Request # 23 - Intraday download COMPLETE for @EUU14. Completion time: 0s | 2014-07-04 08:49:12 Real-time Intraday chart data file updates started for @EUU14 | 2014-07-04 08:49:12 CTS T4 FIX - Starting real-time market data updates for: 6E.20140900.CME_Fo. ID: 3 | 2014-07-04 08:49:12 HD Request # 24 - Downloading Intraday chart data for 6E.20140900.CME_Fo to the file 6E.20140900.CME_Fo.scid. Service: cts | 2014-07-04 08:49:12 HD Request # 24 - Performing multistage download. Downloading Minute data first. | 2014-07-04 08:49:12 HD Request # 24 - Download start Date-Time: 2013-12-30 07:49:12.0 | 2014-07-04 08:49:12 HD Request # 24 - Disabling Intraday chart updating for symbol during historical data download. | 2014-07-04 08:49:12 CTS FIX Historical Data - Connecting to Historical data server fix-chart-sim.t4login.com:10443 | 2014-07-04 08:49:12 Chart #2 has tagged chart #6 for full recalculation. Chartbook: Monsetup.cht | 2014-07-04 08:49:12 CTS T4 FIX: Sending security definition request for symbol 6E.20140900.CME_Fo | 2014-07-04 08:49:12 Chart #6 is performing a full recalculation because it has been tagged. Chartbook: Monsetup.cht | 2014-07-04 08:49:12 CTS T4 FIX: Received matching security definition for symbol 6E.20140900.CME_Fo. Subscribing to data. | 2014-07-04 08:49:13 CTS T4 FIX: Received 1 security definitions for underlying symbol 6E | 2014-07-04 08:49:13 CTS FIX Historical Data socket (0) - Resolved address fix-chart-sim.t4login.com to IP 74.201.6.229 | 2014-07-04 08:49:13 CTS FIX: Received a Reject <3> message. Reference Sequence Num = 5. RefTagID = 265. Reference Message Type = V. SessionRejectReason = 5. Text = Value is incorrect (out of range) for this tag | 2014-07-04 08:49:13 CTS FIX: Received a Logout message. Text = MDUpdateType Tag (265) is out range - Please use range 0 to 10 | 2014-07-04 08:49:13 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2014-07-04 08:49:13 CTS FIX socket (3372) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-04 08:49:13 CTS FIX socket (3372) - SSL has been shut down. | 2014-07-04 08:49:13 CTS FIX socket (3372) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:49:13 CTS FIX socket (3372) - Shutdown and closed. | 2014-07-04 08:49:13 CTS FIX: Logged out and disconnected. | 2014-07-04 08:49:13 Connection to the external service has been lost. | 2014-07-04 08:49:13 CTS FIX Historical Data socket (3468) - Connected. | 2014-07-04 08:49:13 CTS FIX Historical Data socket (3468) - Starting SSL connection. | 2014-07-04 08:49:13 HD Request # 24 - Download canceled. | 2014-07-04 08:49:13 HD Request # 24 - Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for 6E.20140900.CME_Fo | 2014-07-04 08:49:13 HD Request # 24 - Intraday download COMPLETE for 6E.20140900.CME_Fo. Completion time: 1s | 2014-07-04 08:49:13 Canceling download request for 6E.20140900.CME_Fo Intraday data. | 2014-07-04 08:49:13 CTS FIX Historical Data socket (3468) - SSL object has been freed. SSL state is now disconnected. | 2014-07-04 08:49:13 CTS FIX Historical Data socket (3468) - Shutdown and closed. | 2014-07-04 08:49:13 CTS FIX Historical Data: Socket connection was closed without any logout messages sent or received. | 2014-07-04 08:49:13 CTS FIX Historical Data: Disconnected. | 2014-07-04 08:49:13 CTS FIX: Disconnected. | 2014-07-04 08:49:13 Will reconnect to the server in 3.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-07-04 08:49:13 File >> Disconnect selected. | 2014-07-04 08:49:14 CTS FIX: Disconnected. | 2014-07-04 08:49:14 |
[2014-07-04 07:28:20] |
This is the problem: CTS FIX: Received a Reject <3> message. Reference Sequence Num = 5. RefTagID = 265. Reference Message Type = V. SessionRejectReason = 5. Text = Value is incorrect (out of range) for this tag | 2014-07-04 08:49:13 CTS FIX: Received a Logout message. Text = MDUpdateType Tag (265) is out range - Please use range 0 to 10 | 2014-07-04 08:49:13 Select Global Settings >> Data/Trade Service Settings. Make sure that Data Throughput and Buffering is set to one of the listed items. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
