Date/Time: Sat, 27 Apr 2024 11:10:21 +0000
tool.UseToolCfgNum = 1; not picking up line style and line width changes
View Count: 999
[2014-07-04 01:33:05] |
onnb - Posts: 660 |
I am drawing using tool.UseToolCfgNum = 1; I am on build 1145 I am seeing that if I update color in the tool config from Global Settings it works great. I can also update Mark on both ends and that is works too. If I update the line style or line width in the tool configuration, these for some reason are not picked up when I draw from ACSIL. my code looks something like this: s_UseTool tool;
tool.Clear(); tool.ChartNumber = sc.ChartNumber; tool.Region = 0; tool.DrawingType = DRAWING_LINE; tool.LineNumber = line.lineNumber; tool.AddMethod = UTAM_ADD_OR_ADJUST; tool.UseRelativeValue = 0; tool.BeginIndex = line.x1; tool.EndIndex = line.x2; tool.BeginValue = line.value; tool.EndValue = line.value; tool.UseToolCfgNum = 1; sc.UseTool(tool); Date Time Of Last Edit: 2014-07-04 01:33:37
[2014-07-04 06:32:33] |
We will check on this.
[2014-07-04 13:43:52] |
Al SC Developer - Posts: 434 |
This will be addressed in ver 1157.
