Date/Time: Sun, 05 May 2024 13:02:39 +0000
Не подгружаются исторические данные
View Count: 938
[2014-07-03 05:56:39] |
User60651 - Posts: 6 |
Здравствуйте. Не могу загрузить исторические данные для нефти WTI (CL) (August) и S&P500 (ES) (September) для Intraday чарта. Если открываю Historical Chart, то данные грузятся. Но мне нужна история на Intraday Chart. Вот записи из лог-файла: HD Request # 9 - Requesting historical Minute data for ES.20140900.CME_Eq from 2013-12-28 00:00:00 to 2013-12-28 00:00:00 (US Central Time). | 2014-07-03 11:42:57 CTS FIX Historical Data: Received a Reject <3> message. Reference Sequence Num = 2. RefTagID = 265. Reference Message Type = V. SessionRejectReason = 1. Text = Required tag missing | 2014-07-03 11:42:57 CTS FIX Historical Data: Received a Logout message. Text = MDUpdateType Tag (265) is Missing | 2014-07-03 11:42:57 CTS FIX Historical Data: Sending a Logout message. Text = Received Logout message. | 2014-07-03 11:42:57 CTS FIX Historical Data socket (1860) - SSL shutdown indicates not able to send 'close notify'. | 2014-07-03 11:42:57 CTS FIX Historical Data socket (1860) - SSL has been shut down. | 2014-07-03 11:42:57 CTS FIX Historical Data socket (1860) - SSL object has been freed. SSL state is now disconnected. | 2014-07-03 11:42:57 CTS FIX Historical Data socket (1860) - Shutdown and closed. | 2014-07-03 11:42:57 CTS FIX Historical Data: Logged out and disconnected. | 2014-07-03 11:42:57 CTS FIX Historical Data: Disconnected. | 2014-07-03 11:42:57 Что может быть, подскажите. В кабинете t4login.com галочки в additional functionality не ставил, мне сказали что это не нужно есль используешь сиерру чартс. В биржах выбрал CME и NYMEX с опциями Depth $5. |
[2014-07-03 06:32:09] |
This problem has been resolved: CTS FIX Historical Data: Received a Reject <3> message. Reference Sequence Num = 2. RefTagID = 265. Reference Message Type = V. SessionRejectReason = 1. Text = Required tag missing | 2014-07-03 11:42:57 Update Sierra Chart by selecting Help >> Download Prerelease. After the update you can then re-download the data in the chart by selecting Edit >> Delete All Data and Download. In regards to exchanges, contact CTS with questions about those. You will need to activate the exchanges through the T4 website that you want to receive market data for within Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-03 06:32:44
