Date/Time: Mon, 06 May 2024 06:11:44 +0000
minimum price change
View Count: 929
[2014-07-03 04:42:36] |
User55865 - Posts: 7 |
what is the minimum price change on nazdaq 100? on my chart is 1, (ex: 1300.00 to 1301.00) is it correct?
[2014-07-03 04:44:15] |
With the SC Forex/CFD Data Service you are using, the Tick Size you see in Chart >> Chart Settings is correct for that symbol.
[2014-07-03 08:30:40] |
so, what choices do I have to get smaller price changes on my charts? (ex: .50, .25) this is crustal for a day trader. |
[2014-07-04 03:37:36] |
You cannot change the actual prices from the data feed but you can try decreasing the Tick Size in Chart >> Chart Settings.
[2014-07-04 07:31:05] |
what i understand is that, if i want to ex:(go long nq100 on 1300.50) i have to change my data feed. correct? because when i change the tick size from 1 to .50 on (cs), still i can not enter the market on, smaller than 1 price change.
[2014-07-04 07:52:40] |
The NASDAQ 100 you are looking at when using the SC Forex Data (FXCM) service is a CFD (contract for difference) market. It is not the same as the futures prices. You would have to use a futures data feed. Sierra Chart supports various futures data feeds. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
